Hi All,
Many thanks for the helpful info, I will try and examine Rcon plus the resistors inline and extra caps as mentioned, and let you know the results.
MR RB
Does your MAX232 have all the required caps, there should be quite a few caps there and none are shown.
Yes, its the standard max232 chip with 1uf caps, 4 on the voltage doubler plus 1uf on the +5v rail as Maxim show plus a 100nf; though seems , as you say, it needs a much bigger value, easily corrected
Languer
The FT232 has been replaced with the Max232.
The board does have 100nf on every chip but most were smd so hard to see on that pcb layout.
(The diagrams were just for personal reference so not complete in every detail. )
Again, as with Mr.RB, looks as if I should have fitted more higher value decouplers, which I can still do along with the stronger ground wire you mention.
One point that may have some relevance, though I can never get to the bottom of, the Pics psu has the +5v and 0v line, typically refered to a ground.
Should this 0v 'ground' be connected to mains Earth or should they be kept separate, using the Earth for cable shielding etc ?
Currently Earth is not connected to 0v Ground
