The current your parallel port will sink or source will eb dependent on the amount of load you have. I=V/R not V=I/R. Current is a FUNCTION of voltage. If the parallel port is trigerring your transistors even it is in its low state, probably you're transistor is not biased properly and check if your PC and circuit has the reference point or ground level.
