Require Help with Designing a Circuit for a Project
alec_t
Most Helpful Member
Is your above circuit similar to this one??
No. Mine doesn't use any relays.
Where would I add the pot on the stripboard?
Wherever is convenient.
would I still require diodes?
AsI said, "This new circuit also includes two diodes which effectively disconnect the pot when neither switch is pressed, to avoid current drain when the circuit is not in use, and so eliminate an 'off' switch."
If you omit the diodes the 10k pot will waste about 1mA when the circuit is idle, reducing battery life.
jctproject
Do you think your circuit would be a more effective option to make than the one I've shown??
alec_t
Most Helpful Member
Naturally ;). I guess it depends on what you mean by 'effective' though. Mine doesn't need relays (hence uses less current) or an off switch. Nor do you need to make pads for touch switches (which in any case depend for their operation on skin resistance, which varies widely making them somewaht 'iffy'). The two diodes are only a few cents/pence each.
alec_t
Most Helpful Member
Herewith revised circuits including improved voltage spike-suppression features.
The non-latching version should handle a wider range of skin resistance across the touch-switch contacts.
The switching logic has been simplified.
EE World Online Articles
Loading
