MadJackTheFirst
Hello everyone, first time here and first post.
I have an old monitor that I repaired in the past, replaced several capacitors, but now I'm facing a problem I do not know how to diagnose, much less fix. Although, truth be told, I have tried. Unsuccessfully.
The monitor, after being turned on (and connected to the video card), will, after about a second, emit a high pitch noise and then will turn black. If I turned it off and on, the same thing happens; it does not stay off for X time.
At first, when the behavior started, simply toggling on/off would fix it, but now that, obviously, does not work anymore.
What I have done so far:
I thought the INVERTER TRANSFORMER had died and replaced it (the noise seemed to come from it), but to no avail. The result remained the exact same.
I then bought a new replacement POWER BOARD for the monitor. Unfortunately, there was no change.
At this point I would like to be able to diagnose where the problem comes from and try to come up with a working solution. I am not sure if I will repair it in the end because I am starting to see that it might be more sensible to buy a new monitor as they are fairly inexpensive.
So, what would be the culprit? What could emit a high-pitched noise after it had warmed up a bit?
I can provide pictures or more information as needed.
Thank you.
Thank you.
