Repaired my microwave today
Lo_volt
A few months ago, my microwave started tripping the circuit breaker whenever anyone pulled the door open while the magnetron was running. It never happened when we paused or stopped cooking before opening the door. Yesterday, my daughter pulled the door open in that specific manner and the microwave stopped working altogether. I checked the breaker and it wasn't tripped. It seemed the microwave was bricked.
Today I had the opportunity to open it and I found that the internal fuse was blown. The unit had a service pamphlet tucked inside so i pulled it out and looked it over. There was a whole section about a "monitor switch". I had to google what that was and interestingly enough, its function is to blow the fuse if it is still closed while the magnetron is energized i.e. door open and magnetron on. Being a 20 amp fuse it was a toss up whether the internal fuse blew or the house circuit breaker tripped. Finally, yesterday, the internal fuse bit the dust.
In poking around inside, I found that the monitor switch was very loose in its mount. A layer of tape tightened it up. Apparently the loose switch was still closed while the door interlock switches said the door was open and magnetron running. The tape tightened the switch in its mount and fixed the issue.
I guess this post is a heads up that GE microwaves have a monitor switch.
It's also a bit of a complaint that there's no indication of that specific fault. Those who are less technically inclined would likely have tossed the unit and bought a new one. This despite the possibility of a cheap fix.
Microwave ovens have had switches like that for a long time, at least 40 years.
The switch is there in case other switches fail with the contacts closed for any reason. It is not designed to be used lots of times and you should get a new switch. You should check that the power to the magnetron is being shorted when the door is open. You can check that with a multimeter if you measure in the right place.
Indeed, i pulled the switch and checked its function. Had it been sticky or seemed otherwise flaky I would have replaced it. It snaps into place so it has to have some slop. In my situation there was just a fraction of a second where the two door switches were in the closed state and the monitor switch was in the open state.
I knew microwaves had doubled up door switches but I did not know about the monitor switch. I can appreciate the redundancy as you really, really want to avoid a door open and magnetron on situation.
It's what's known as a 'crowbar' circuit - a last ditch safety feature. Basically two of the door switches turn it OFF - if they should fail, the monitor switch blows the fuse to make it safe.
As an ex-microwave oven engineer I would suggest it's good idea to replace at the monitor switch if it's been triggered - needless to say a microswitch directly across the mains takes a lot of stress.
As others have mentioned, microwave ovens are EXTREMELY dangerous, the voltages and currents involved WILL kill you - in the UK you would probably struggle buying a replacement fuse, as no authorised service facility is allowed to sell you one.
That thought came to me at 3:00 in the morning. I've already ordered one.
I get the thought process behind it. I think it was intended for the case where both door switches have failed and there's the potential for the magnetron to be operating while the door is open. In my case, I think it was a misalignment of the monitor switch due to the way it was mounted. I've checked them both and they are working properly.
Can you explain why in UK you can't buy 20A fuse?
Well you can't buy microwave fuses here anyway, other than through dodgy sources, as authorised facilities aren't allowed to sell them. But the UK uses 13A 240V mains sockets, so there's no need for a 20A fuse - as I recall microwave ovens were either 6.3A or 8A fuses?.
Congratulations! I would have never dared to open my oven. Thanks for letting us know how you fixed it.
Can you give me a link for such fuse?
Here in Australia you can buy microwave oven fuses from WES components in Sydney. They are commonly 3AG or M205 ceramic with a flame retardent powder inside.
Perhaps regulations are less strict in Aus :D
Or it's just a 'dodgy' company selling parts to all and sundry they aren't supposed to?.
Basically, as an Authorised Microwave Oven service facility we weren't allowed to sell any parts to the public that required the top removing - if we did, we would be stripped of our authorised status.
This limitation included all fuses (as they are all under the top cover) and most oven lamps, although some are accessible through a small flap without removing the top. Wave guide covers were fine.
So basically, you can buy a gun in UK, but not a fuse for microwave oven? :banghead:
In my country you can buy 6.3A fuse for €0.15, but there is a ban currently on gun licensing. :stop:
Fuse
You've obviously not tried buying a gun in the UK :D
Gun control is VERY strict, shotguns are available (assuming you are granted a licence to have one), rifles are available (but harder to get a licence for), handguns are NOT available (other than ball and powder types).
Even the Olympic Shooting team aren't allowed to have guns, they have to fly to Sweden (I think) in order to practice.
Having said that, we had breakfast this morning (a fairly regular Friday treat from work) with a friend who works at a gun shop :D
Basically he sells shotguns etc. - I don't know if he does rifles as well?, but in any case you can't just walk in and buy a gun. It's a family business, and was started by his dad or uncle (I'm not sure which) who was a medal winning Olympic and Commonwealth clay pigeon competitor.
Ah, just wanted to make a point. :sorry:
In my country there is currently a ban on licensing firearms which was introduced after some mass shootings, but it will expire this year.
Otherwise it's fairly easy to buy a gun, or a shotgun.
Automatic firearm sale is prohibited here, but our homemade AK-47 sells like apples in USA. :happy:
And, yes, you can buy fuses as much as you want here.
Point is, you can kill others, but not yourself! :facepalm:
I suspect that strict microwave oven regulations were introduced in order to ensure safety in their use - as such, any microwave oven we repaired had to be power and leakage tested - as such I've tested thousands, and only ever found two which leaked, and they were within permitted levels. Both were the same Philips model, with hinge down doors, rather than hinging from the left -they only latch at one corner, so the other corner tends to spring open slightly.
Personally I imagine a far greater reason for the ban on selling spares is due to the high voltages and currents inside a microwave oven, 240V mains is relatively 'safe' (it can kill you, but you have to work at it) - the voltages in a microwave WILL kill you.
I know loads of people who have had mains shocks (I've had loads myself :D ), but I don't know anyone who has had a shock from a Microwave. I've only heard one story about such a case, and the guy was lucky - Paramedics happened to already be next door, they were there in seconds, and able to resuscitate him - but according to the story, he was never quite right afterwards.
