reading frequency using pic16f877a
Hi all;
i want to measure the frequency of a sin wave passed through HEF4093BE NAND gate Schmitt trigger to be furnished and this frequency is feeded into pin RA2 of PIC16F877A; and from this pin i want to read the frequency. i made the following code for that purpose but instead of reading the frequency it is counting the numbers with a very high speed i think with the clock speed of my 4MHz crystal. plz analyze my code and tell me the mistake. (NOTE: i don't want to use counter pins).
Here are frequency related parts of my code to make it understandable for you.
void interrupt()
     if(PIR1.TMR1IF==1)
        frq=1;
void main()
ADCON1=0x06;   // adc reg initialization
INTCON=0xA0;  // for timer0  ; interrupt reg initilization
 TRISA = 0xFF;     // port A as input
      Lcd_Cmd(_LCD_CLEAR);                    // Clear display
      Lcd_Cmd(_LCD_CURSOR_OFF);
      Lcd_Cmd(_LCD_MOVE_CURSOR_RIGHT);
      Lcd_Out(1,1,CopyConst2Ram(msg,fv));   // Write text in first row
     T1CON.TMR1ON=0;
     PIR1.TMR1IF=0;
     TMR1L=0XEE;    // value loaded for 1 second delay.
     TMR1H=0X85;
              j==1;
              frq=0;
              while(j==1)
                         while(G_freq==1)
                            {G++;}
                                    IntToStr(G,string);
                                    Lcd_Out(2,2,string);
                                    Lcd_Out_CP("Hz");
                         if(mains==P)
                         {j=0;}
                         if(frq==1)
                             k++;
                             T1CON.TMR1ON=0;
                             PIR1.TMR1IF=0;
                             TMR1H=0X85;
                                if(k=4)
                                    IntToStr(G,string);
                                    Lcd_Out_CP("Hz");
                                    Delay_ms(1000);
                                    G=0;
                                    k=0;
                             T1CON.TMR1ON=1;
                             frq=0;
where
#define genr PORTA.F0
#define mains PORTA.F1
#define G_freq PORTA.F2
const char fv[] = "Frequency  Volts";
unsigned char frq=0;
unsigned int j=1,G=0,k=0;
if(k=4)
what the above statement is for?
And what is the error you are facing is it logical or compilation?
sorry i have modified it to
if(k==4)
It is for creating one second delay.
I am facing logical error. Compilation is OK.
i want to measure the frequency at pin RA2 of PIC16f877a.
the code with little modification is:
  while(j==1)
                             if(G_freq==0)    // true at high pulse
                              G++;
                              while(G_freq==1);   // wait untill pulse is high
                                //   IntToStr(G,string);
                                //   Lcd_Out(2,2,string);
                                //   Lcd_Out_CP("Hz");
                         if(mains==P)
                         {j=0;}
                         if(frq==1)
                             k++;
                             T1CON.TMR1ON=0;
                             PIR1.TMR1IF=0;
                             TMR1L=0X00;
                             TMR1H=0X00;
                                if(k==5)
                                      l2=~l2;
                                    IntToStr(G,string);
                                    Lcd_Out_CP("Hz");
                                   // Delay_ms(1000);
                                   // G=0;
                                    k=0;
                             T1CON.TMR1ON=1;
                             frq=0;
                         l2=0;
where l2 is for another LED indicating the timer is runnig and creating 1sec delay .
void interrupt()
if(PIR1.TMR1IF==1)
frq=1;
when the interrupt will get executed when the timer overflow interrupt occurs..
And your timer is only running when the frq=1... the intial value of frq is 0....
And one more thing you have not cleared the timer interrupt flag also....
void interrupt()
if(PIR1.TMR1IF==1)
frq=1;
1)the interrupt will get executed when timer is role over after each 1/4th of a second.
2)no; on execution of interrupt. it will just go and set frq and go back to the while routine and off the timer, display the value of G which is frequency, clear G and K and frq variables and turn the timer ON again.
3)i have cleared it in while routine.
Sorry Qaisar but that is a terrible (not accurate) way to get a 1 second gated period. There are many "PIC frequency meter" projects on the net, most with source code and Microchip appnotes on making a PIC16 frequency meter.
With a 4MHz xtal you have 1MHz timers, so to make 1 second you need to count exactly 1 million ticks. One easy way is to set the TMR2 PR2 to a period of 250 ticks;
PR2 = (250 - 1);
And then the TMR2 interrupt will occur exactly every 250 ticks. So 1 miilion ticks is 4000 interrupts exactly.
Sorry Qaisar I have not seen that you have already cleared the interrupt after execution.
And if it is having the static 0Hz display means may be your value of G is not changing...
