throbscottle
I refer to this design: https://www.electro-tech-online.com/threads/drill-feed-controller-mostly-works.143771.
So, I discovered the modification to U7a D input caused more issues than it solved. I modified the bit that feeds pulses to wind up the dig-pot so it has a small delay - big improvement, the pot gets a chance to be set to go the right way now!
But what is really baffling me is this. It will run fine for a dozen or so down/up transits, but then it will shoot to the top, and the feed motor remains powered, holding it up there. Digi-pot shows to be at minimum value, I have to press the reset switch, then the "top" limit switch to set it correctly again, and off it goes. AFAICT, the digi-pot is failing to be reversed at the bottom of the travel. Can't work out why. It gets a noticeable rest / over-run period at the bottom, and a reliable pulse from the monostable. Maybe it needs a wider pulse, though it's not very narrow.
So any suggestions, anyone?
