RA4 not working???
Alverick
Hi, I'll get to the point: I program PORTA as output, and everytime I write a logic 1 in pin 4 (RA4/T0CKI) it doesn't change. I'm simulating my program in Labcenter ISIS v5 ... it's not the first time that happens, and not only with the 16f628, but with 16f877 and 16f84 (those are the only ones that I was programming lately).. Here is my code:
LIST	P=16F628
	INCLUDE	<p16f628.inc>
	__CONFIG _CP_OFF & _BODEN_OFF & _INTRC_OSC_NOCLKOUT & _DATA_CP_OFF & _LVP_OFF & _MCLRE_ON & _PWRTE_ON & _WDT_OFF & _XT_OSC & _ER_OSC_NOCLKOUT
CounterA	EQU	20h
CounterB	EQU	21h
CounterC	EQU	22h
		ORG	0x00
		goto	INICIO
		ORG	0x04
		goto	inter
INICIO		clrf	PORTB
		clrf	PORTA
		bsf	RCSTA,SPEN
		movlw	0x07
		movwf	CMCON
		movlw	b'11000110'
		movwf	OPTION_REG
		bsf	STATUS,RP0
		bcf	STATUS,RP1
		movlw	b'00000011'
		movwf	TRISB
		movlw	0xFF
		movwf	TRISA
		movlw	b'00100100'
		movwf	TXSTA
		movlw	.25
		movwf	SPBRG
		bsf	PIE1,RCIE
		bcf	STATUS,RP0
		bsf	RCSTA,SPEN
		movlw	b'10010000'
		movwf	RCSTA
		bsf	STATUS,RP0
		bcf	STATUS,RP1
		bsf	TXSTA,TXEN
		bcf	STATUS,RP0
stt		movlw	b'11010000'
		movwf	INTCON
BUCLE		goto	BUCLE
inter		btfsc	PIR1,RCIF
		goto	getdat
		btfsc	INTCON,INTF
		goto	senddat
		goto	stt
getdat		bcf	PIR1,RCIF
		bsf	STATUS,RP0
		movlw	0xE0
		movwf	TRISA
		bcf	STATUS,RP0
		movf	RCREG,W
		movwf	PORTA
		goto	stt
senddat		bsf	STATUS,RP0
		movlw	0xFF
		movwf	TRISA
		bcf	STATUS,RP0
		movfw	PORTA
		movwf	TXREG
		bsf	STATUS,RP0
		bcf	STATUS,RP1
COMP_TX		btfss	TXSTA,TRMT
		goto	COMP_TX
		bcf	STATUS,RP0
		goto 	stt
;PIC Time Delay = 1,0000020 s with Osc = 4 MHz
PDelay		movlw	D'6'
		movwf	CounterC
		movlw	D'24'
		movwf	CounterB
		movlw	D'168'
		movwf	CounterA
loop		decfsz	CounterA,1
		goto	loop
		decfsz	CounterB,1
		goto	loop
		decfsz	CounterC,1
		goto	loop
		return
		END
BTW, the __CONFIG is ok? or i'm doing something wrong there? :S
Greets!!
Does this mean...
1. Is it really to add a pull up resistor to R4 for configuring it as an output... ?
2. One more thing concerning with this... :
What's the reason behind it...?:o
that RA4 is a schmitt trigger input and an open drain output while....
other pins are TTL inputs and CMOS outputs...
Regards,
simran..
Not as such, like any other I/O pin you configure it in the TRIS register. However, as you already know, it's an open drain output - so to make it appear as a normal ouput you need a pull up resistor - RA4 can only sink current, not source it.
To make it more versatile, an open drain output can be very useful, as can a schmitt input.
sorry sir...
YES.. i got it...
The purpose of schmitt trigger is.. that to give output high when the voltage is more than a certain value..
and lower when input is lower than certain value... as seen here...
Good technique...:)
