R in parallel- Check my math please...
RogerTango
If you would please check my math, I would appreciate it...
Goal: 1.25Ω @ 2w power capability
Wired: 4X 5Ω 1/2w resistors in parallel
1/5 + 1/5 + 1/5 + 1/5 = .8
1/.8 = Rt, 1/.8 = 1.25Ω
1/2(w) + 1/2(w) + 1/2(w) + 1/2(w) = 2(w) power rating
Final answer: 1.25Ω @ 2w power rating
Is this correct please?
Thanks,
Andrew
Yep, just fine.
Ron
Your math is correct but I wouldn't dissipate more than about 1.5W total in those resistors for best reliability.
Oh yes,
Your math is correct. You have a 1.25 Ohm 2 Watt resistor but you would not want to have it dissipate the max of 2 watts. I should have mentioned that as Carl points it out.
Ron
Thank you kindly, not running 100% w noted... I only needed 1.7w, so I already buffered up! :)
Andrew
That's not enough overhead for a lot of situations. The 1/2W rating is if they are free standing in cool air, and 4 resistors togther will heat each other.
You need to make sure they are up off the PCB and well away from each other, and hopefully with some air cooling (not a sealed enclosure).
If it was me I woudl just use a 1.2 ohm 5W resistor and mount it a bit above the PCB.
