PWM led Dimmer 18f1220
be80be
A simple PWM led dimmer with the 18F1220 here the code you can use it with and 18fxxx just need swordfish basic. And Thanks to 3v0
Dim Duty As Word               // local duty variable...
Dim sw0 As PORTA.0
Dim sw1 As PORTA.1
Input (sw0)
Input (sw1)
SetAllDigital
// main program...
If PWM.SetFreq(5000) Then
Duty = 0
 While true
      PWM.SetDutyPercent(Duty)
      If ( (sw0 = 1) And (Duty < 10) ) Then
      Inc(Duty)
      DelayMS(10)
      While sw0 = 1 Wend
      EndIf
      If ( (sw1 = 1) And (Duty >0) ) Then
      Dec(Duty)
      DelayMS(10)
      while sw1 = 1 wend
      EndIf
   Wend
EndIf
Now the video not that good it better live hard to film a led
And here the same code but I'm dimming a ac light bulb
Can you post the full code and all the modules. Becasue when i compile your code with the swordfish PWM.BAS i get a few errors.
Here the whole code lol I didn't post the chip and osc you may want to use a 18f1230 I just happen to have 18f1220. But any way I added that to just to make it easy.
 Device = 18F1220
Clock = 8
Config OSC = INTIO2
Include "INTOSC8.bas"
Include "PW.bas"            // import PWM module...
Include "Utils.bas"
Dim sw0 As PORTA.0
Dim sw1 As PORTA.1
Input (sw0)
Input (sw1)
SetAllDigital
// main program...
Duty = 0
 While true
      Inc(Duty)
      DelayMS(10)
      While sw0 = 1 Wend
      EndIf
      Dec(Duty)
      DelayMS(10)
      While sw1 = 1 Wend
      EndIf
   Wend
EndIf
you need to add 2 files to your user User Library the IntOSC8 and PW I uploaded them
I thought some of you may want to see how you do this so i took some
Pictures and some more just to walk you thew it.
Some are not to clear but after 4 sets of battery
I stopped trying to get a clear shot. Maybe some one will have as much fun as I did with
