Pushing/Pulling
YAN-1
Hello. I was looking at a VCO datasheet and it said that it had good pushing and pulling performance. What does rf pushing and pulling mean exactly? Thanks a lot.
Nichola V Abdo
I think pushing and pulling of an oscillator are when the frequency changes when the supply voltage changes and maybe when the load resistance changes.
In some systems the osc is p/p by varying the Vbias on a varicap in the osc tuning circuit.
IIRC often used in electronic musical instruments.
I agree with you.
Frequency pushing is the sensitivity of the output frequency to the supply voltage.
Frequency pulling is the sensitivity of the output frequency to the load conditions.
RadioRon said:
hi Ron,
IIRC this explains the undesirable 'side effects' that one can get from these sources.
But some applications, musical instruments etc, the VCO is designed so that it can be pulled in a controlled way to produce a desired effect.
ericgibbs said:
hi Ron,
Hi Eric
My limited understanding of these terms comes from the world of wireless product design and in that industry these terms have the specific meanings referred to in my reference. I'm not surprised that they may have additional meanings in other industries as we often find that the meanings of words and phrases depend on the context of their use. Thanks for the info.
I thought pushing and pulling in concerns to a VCO were the intentional effects. I'm guessing it means it has a wide range of frequency responce in the given voltage range. Something that has bad push-pull performance might require more drive voltage for a given frequency shift. That's the way I read it at least in concerns to a VCO.
That's it
Lefty
That's what I thought until I did a little research. That's why I edited my previous post.
http://www.freepatentsonline.com/4518930.html
In brief
Furthermore, for efficiency reasons, it is also desirable to have a wide span of FM control of the oscillator. A common measure of the span of control is often called "pullability" of the oscillator, and refers to an extent that an oscillator can be modulated.
Oscillator parameters such as frequency pullability, startability, stability, temperature, and crystal drive are easily optimized and can be set by mutually independent selection of individual circuit element values. In particular, the crystal drive level is well controlled due to the well-defined limiting character of the negative resistance circuit.
Frequency stability (which should include VCC stability) and pullability are listed as seperate paramaters. But the first link mentions that they're linked, meaning something that is highly pulable is always going to be less stable to circuit conditions. While it obviously refers to both in the context of a VCO I'm certain it refers to the span of frequency variation with a given input signal.
High Pullability Voltage Controlled Oscillator
A voltage controlled crystal oscillator was developed which has extended tuning range while main- taining good Cl and temperature stability. With the circuit values indicated in the attached figure, * f .045% tuning was achieved over a 2.12V steering line change.
I see it refered to a lot with using different value capacitors to slightly trim the frequency of a crystal oscillator as well.
That's what I found doing a Google search in about 3 minutes. How is the opposite conclusion being reached by other people?
In brief
Apparently it depends on your search parameters. As I said, my original thoughts were what you verified here. But try searching for "VCO pushing pulling" and you get mostly the opposite result.
I'm surprised that you guys are still going on about this. When it comes to a VCO data sheet, the VCO industry has decided to use Pulling and Pushing to mean those specific things referred to in this link given previously (https://www.electro-tech-online.com/custompdfs/2007/10/vco15-15-2.pdf). If, on the other hand, one is discussing the principles of oscillators in general, then, yes, the pullability of an oscillator is generally its ability (or its weakness, depending on your point of view) to change its frequency of oscillation due to external influences. This is analogous to the use of many words in English that have different meanings depending on their context. The original poster was asking in the context of a VCO data sheet.
