Push button
Hello guys Iam testing a button, This is how I want my project to work. When a button is pushed or pressed the three LEDs must be on.But when I push the button the LEDS do not light. can any one help me. On the attachment I have the design (proteus design) and the hex file. the code for my project is shown below
	list      p=16f877            ; list directive to define processor
	#include <p16f877.inc>        ; processor specific variable definitions
	__CONFIG _CP_OFF & _WDT_OFF & _BODEN_ON & _PWRTE_ON & _RC_OSC & _WRT_ENABLE_ON & _LVP_ON & _DEBUG_OFF & _CPD_OFF
;***** VARIABLE DEFINITIONS
w_temp        EQU     0x7E        ; variable used for context saving
status_temp   EQU     0x7F        ; variable used for context saving
		ORG     0x000             ; processor reset vector
		clrf    PCLATH            ; ensure page bits are cleared
  		goto    Main              ; go to beginning of program
		ORG     0x004             ; interrupt vector location
		movwf   w_temp            ; save off current W register contents
		movf	STATUS,w          ; move status register into W register
		movwf	status_temp       ; save off contents of STATUS register
; isr code can go here or be located as a call subroutine elsewhere
		movf    status_temp,w     ; retrieve copy of STATUS register
		movwf	STATUS            ; restore pre-isr STATUS register contents
		swapf   w_temp,f
		swapf   w_temp,w          ; restore pre-isr W register contents
		retfie                          ; return from interrupt
Init
        clrw                 ; Zero.
        movwf   PORTB        ; resets input/output ports
        bsf     STATUS,RP0   ; Select Bank 1
        movlw   b'00000000'  ; Set port B bits as outputs
        movwf   TRISB        ; Set TRISB register.
        bcf  STATUS,RP0      ; Select Bank 0
        retlw 0
Main
        call Init
button_pressed
         btfss PORTA,0       ;check whether button is pressed
         goto button_pressed ; if not pressed keep checking or looping
         goto loop          ; if pressed then turn on the LEDs
loop
        bsf  PORTB,0  ;turn on the red light
        bsf  PORTB,1  ;turn on the yellow light
        bsf  PORTB,2  ;turn on the green light
        goto loop
 end
  • button.zip
hi
You have the inputs of PORTA set as Analog.
hi
oh thanks, I have edited it to
		swapf   w_temp,f
Init
        clrw                         ; Zero.
        movwf   PORTA        ; resets input/output ports
        movlw   b'00000001'  ; set RA1 as input pin
        movwf   TRISA        ;set TRISA register
        retlw 0
Main
        call Init
button_pressed
loop
        goto loop
 end
and still it did not work
Look at this, it works.
Add the two line into your init
     movlw    0x07
    movwf    ADCON1
Init
        clrw                 ; Zero.
     movlw    0x07
    movwf    ADCON1
        retlw 0
Iam so happy it works. The way I know assembly is that, I had to make sure that PORTA, pin 0 is the input by initialising it
such that this instraction
can work, So I decided to include this instractions on the initialisation
I would be glad if you can tell me why it is working when using these instructions
 movlw    0x07
 movwf    ADCON1
Thank you very much
When the PIC powers up, the AN0 pins are always initialised as analog inputs, so if you want to use them as digital inputs you MUST use ADCON1 in the 16F877.
Look at the datasheet for the 16F877 in the ADCON1 section it explains the init.
Thank you very much, I have even modifeid the code, now when you push/press the button the LEDs light and when you release the button the LED's light turn off.
button_pressed
         goto  released     ; if not pressed turn the LEDs off
         goto pressed       ; if pressed then turn on the LEDs
pressed
        goto button_pressed
released
       bcf PORTB,0    ;turn off the red light
       bcf PORTB,1    ;turn off the yellow light
       bcf PORTB,2    ;turn off the green light
       goto button_pressed
