psu design with the lm350
tjalf
hi there.. hope you can help me...
i got a 24VAC 3,6A transformer and i need to make an 6.3V 3A powersupply...
can the lm350 be used for this?? i have looked at the pdf files from national.com but my brain cant get the idea of the schematics...
is the someone who could help me??
thanks for your time :)
The transformer is really far too high a voltage, the regulator would need to dissipate about 100W of heat!.
You mention 6.3V, this is the standard heater voltage for 'E' series valves, is it for a valve heater supply?.
the o/p voltage is V=1.25(1+R2/R1)
so for ur needs make R2, 4 times that of R1 ,
R1- 470 and R2 1.9K will do (1.8K+100)
thats correct... how small transformer should i den have??
i can get an 2*6v 2×3333mA transformer to an ok price would it be to small??
Historically valve heaters were fed with AC directly from a transformer, there's no need for either DC or regulation. If you can't find a specific heater transformer the 6V one mentioned above should work fine.
