Programming timer0 in PIC 16f628
If you trace the path of execution you will see that the portion I highlighted (plus the return instruction) never gets executed.
i got it ............. thanks a heaven.......
in another part of the coursework i am required to use delay functions to generate delay of 1sec, 750ms, 500ms and 250ms.
can you check that the code i wrote for the delay function is correct??
delay1s movlw D'1249994' ;
movwf D_Ctr1 ;
D_L1 nop ;
decfsz D_Ctr1 ;
goto D_L1 ;
nop ;
return ;
delay750ms movlw D'937498' ;
movwf D_Ctr1 ;
D_L1 nop ;
decfsz D_Ctr1 ;
goto D_L1 ;
nop ;
return ;
delay500ms movlw D'624994' ;
movwf D_Ctr1 ;
D_L1 nop ;
decfsz D_Ctr1 ;
goto D_L1 ;
nop ;
return ;
delay250ms movlw D'312494' ;
movwf D_Ctr1 ;
D_L1 nop ;
decfsz D_Ctr1 ;
goto D_L1 ;
nop ;
return ;
Your theory is correct as to how you would generate a delay but unfortunately the biggest number that W can hold is 255 and so movlw D'624944' would actually load W with 48. For seeing how longer delays are generated see .
One other thing, when posting code if you type
 before it and
after it then it will keep it's format.
