If you scroll down and look at the address 0x7F9 you'll see more data which is the actual program location. C compilers sometimes create strange assembly code.:02000000F92FD6
:0E0FF200FF3083120313860083168601FF2F43
:00000001FF
kchriste said:You should also have pullups on the unused pins or program them as outputs
#include<pic.h>
#include<htc.h>
__CONFIG(0x3f79);
void main()
PORTB = 0xFF;
TRISB = 0x00;
while(1);
#include<pic.h>
#include<htc.h>
__CONFIG(0x3f79);
void delay(void);
void main()
TRISB = 0x00;
while(1){
PORTB = 0xFF;
delay();
PORTB = 0x00;
delay();
void delay(void){
int i;
for(i=0;i<15000;i++);
As pointed out, 4 MHz crytals use 'XT' for oscillator configuration instead of 'HS', or the oscillator might not start (from my experience). Added configuration labels for Hi-Tech PICC with your setup.DMW said:i have set mine to:
Oscillator = HS
Watchdog timer = off
Power-up timer = on
Brownout detect = off
Low voltage program = disable
Flash program write = write protection off
Data EE code protect = off
Code protect = off
HEX: 3F32
4Mhz crystal with 2 x 22pf capacitors
#include <htc.h>
__CONFIG ( XT & WDTDIS & PWRTEN & BORDIS & LVPDIS & UNPROTECT );
void main(){
PORTB = 0; // clear PORTB
TRISB = 0xFE; // RB0 is output
RB0 = 1; // set RB0
while(1); // loop forever
#include<pic.h>
#include<htc.h>
__CONFIG(0x3f79);
void delay(void);
void main()
TRISB = 0x00;
while(1){
PORTB = 0xFF;
delay();
PORTB = 0x00;
delay();
void delay(void){
int i;
This header makes your code more portable. You don't need to include <pic.h>, because the header file htc.h determines which compiler is running and include the specific header file (pic.h, pic18.h, etc.)DMW said:btw what does
#include<htc.h>
do? that might of been whats missing.
DMW said:ok after abit of testing it turns out the error was the configuration bits
DMW said:I was about to look this up, but seeing as im posting here anyway, if i want to set a specific port as an 1 or 0 without changing any of the other ports within a register output, how is it done
example, i want to change B3 from 0 to 1 say without redefining the entire register for B,
can you do it like arrays?
PORTB[3] = 1?
because that's not working for me :S
You mean the PIC won't draw extra current when all the input pins are floating at around 1/2 Vdd? Always thought that it would. Maybe I'll experiment with this later.Nigel Goodwin said:It makes no difference whatsoever, it's a fallacy based on that requirement for CMOS logic gates.
kchriste said:You mean the PIC won't draw extra current when all the input pins are floating at around 1/2 Vdd? Always thought that it would. Maybe I'll experiment with this later.
