PROGRAMMING HELP?
JATEU_01
At the momnet i cant programme for toffee, can any one help with the following or point me to a web site with an idiots guide.?
Project as follows
12v and 5 v circuit
pic16f819
4mhz ex clock
i need a programme to do the following
initiate process buy a momontary switch
next it will have to check three switches before system can activate a relay
at the same time as the relay is activated i am looking for a buzzer and led to be used for visual and audable indication of process working.
and last but not least i need to be able to stop process at anytime by the switch that started process
i can build circuit around the pic...
if anyone can help i would be thankfull..
thank you for your time and help
James fraser
JATEU_01 said:
At the momnet i cant programme for toffee, can any one help with the following or point me to a web site with and idiots guide.?
Project as follows
12v and 5 v circuit
pic16f819
4mhz ex clock
James fraser
Did you read the Sticky? "Read this!" in my signature has valuable info for you. Nigel Goodwin's tuttorials should help you to start.
