Program did not return error but __Lib_Delays.c & P16F876A.c
sanjoy
My RTC project made of 16f876A, 1307, 1820 devices with clock 8MHz. The Program is compiled using mikroC Pro for PIC. The written program didnt return any errors but the associated file " __Lib_Delays.c " & "P16F876A.c" returns some errors after compile. I cannot go ahead for the errors. if anyone know the solution pls let me know. thanks.
The written program attached here as zip.
The Errors is as follows:
0 1 mikroCPIC1618.exe -MSF -DBG -pP16F876A -DL -O11111114 -fo8 -N"E:\CKT\program_edt\MyProject_Clock.mcppi" -SP"C:\Users\Sanjoy\Documents\Mikroelektronika\mikroC PRO for PIC\defs\" -SP"C:\Users\Sanjoy\Documents\Mikroelektronika\mikroC PRO for PIC\Uses\P16\" -
0 126 All files Preprocessed in 343 ms
0 122 Compilation Started MyProject_Clock.c
200 123 Compiled Successfully MyProject_Clock.c
0 122 Compilation Started __Lib_Delays.c
1 393 'Get_Fosc_kHz' Identifier redefined __Lib_Delays.c
7 393 'Delay_1us' Identifier redefined __Lib_Delays.c
11 393 'Delay_10us' Identifier redefined __Lib_Delays.c
15 393 'Delay_22us' Identifier redefined __Lib_Delays.c
19 393 'Delay_50us' Identifier redefined __Lib_Delays.c
23 393 'Delay_80us' Identifier redefined __Lib_Delays.c
27 393 'Delay_500us' Identifier redefined __Lib_Delays.c
31 393 'Delay_5500us' Identifier redefined __Lib_Delays.c
35 393 'Delay_1ms' Identifier redefined __Lib_Delays.c
39 393 'Delay_5ms' Identifier redefined __Lib_Delays.c
43 393 'Delay_8ms' Identifier redefined __Lib_Delays.c
45 312 Internal error '' __Lib_Delays.c
0 122 Compilation Started P16F876A.c
2 393 'B0' Identifier redefined P16F876A.c
3 393 'B1' Identifier redefined P16F876A.c
4 393 'B2' Identifier redefined P16F876A.c
5 393 'B3' Identifier redefined P16F876A.c
6 393 'B4' Identifier redefined P16F876A.c
7 393 'B5' Identifier redefined P16F876A.c
8 393 'B6' Identifier redefined P16F876A.c
9 393 'B7' Identifier redefined P16F876A.c
11 393 '__FLASH_SIZE' Identifier redefined P16F876A.c
14 393 'R0' Identifier redefined P16F876A.c
15 393 'R1' Identifier redefined P16F876A.c
15 312 Internal error '' P16F876A.c
0 102 Finished (with errors): 27 Dec 2014, 11:15:44 MyProject_Clock.mcppi
I have looked through this project.... I belive that it has become corrupted because the original CCS code has tried to include parts that shouldn't have been..
Try and remove delays and the processor files from the library manager.... ie unselect everything and recompile..
Worst case.... write a small delay routine and just leave the lib delay.c out of the compile... Change you code to suit the newer pin definitions.... RB6_bit instead of PORTB.F6... Then at least it should work
Actually a re-think..... The errors with the lib delay.c is down to the soundplay() routine if you comment this out then it will leave out those errors... I had to re-write the sound routine ... I have sent a email to MikroE and they are looking in to it.... If all else fails try the delay_cyc() function...
Delay_Cyc_Long(16394); // 16394 cycles pause
Or..
Delay_Cyc(1, 10); /* 1x16384 + 10 = 16394 cycles pause */ For shorter delays
If you make a function called DelayMs() and call Delay_Cyc() with the amount of clock cycles that creates a ms delay you will have your own Ms delay to call...
