Progpic2 Programming software
david miles
Hi.
I am just starting with pic programming.
I have just got my Velleman 8048 programmer board and included software working ( thanks to help from this board! )and have managed to get the example led programme working OK.
Next, I tried to grab some simple programmes off the web, to blink a led. Although I have saved these programmes as .HEX files, each time I try to get the programme into the chip via the Progpic2 software, I get either "com-init-error" or "no config-word in file!" messages. Can anyone explain to me what I am doing wrong?
David Miles.
Are the HEX files the correct ones for the PIC you're trying to program?.
The "no config-word in file!" message means just that, that the config fuse information isn't included in the HEX file - a very poor piece of programming!, and it's hardly difficult?.
The code is for a 16F84. I am using a 16F84A. The code examples ( timer1 )are from:-http://www.pages.drexel.edu/~tdn26/IntrotoPic/IntroToPic.html
I managed to compile the "timer1" code with MPASM, but I get the "no config-word in file!" when I try to use Progpic2.
Any ideas?
David Miles.
Any ideas?
David Miles.
You need to specify the fuse settings you want in the source code, you use the '__CONFIG' directive to do so - if you check my tutorials I just use the HEX value of the settings I want, but you can specify the individual bits, however I find it rather long winded!.
