problem with serial port interfacing
froten
Hello,
Im tring to write a program for AT89C51 that can send a stream of one character (which is 5) to the computer, I wrote this program but it doesn't work because I didn't see any signal going out from the Tx pin using the osciloscope. the program is as follows:
mov TMOD,#20
mov TH1,#-3
mov SCON,#50
SETB TR1
AGAIN:
mov a,"5"
acall TRANS
sjmp AGAIN
TRANS:
mov SBUF,a
HERE:
jnb TI,HERE
CLR TI
ret
end
the buad rate should be 9600 bps. I didn't actually connect the circuit to the computer because when I use the osciloscope I don't see any signal on the Tx pin. I have attached both the asm and hex files for more information.
Please any help on this issue is appreciated as it is very important for me to get it working.
all i can give you right now is this file,
it helped me a lot when i was trying to setup the UART in my AT89C52..
