Problem with IF, THEN, ELSE and END IF?
Izadysadr
define osc 4
Digit1 var byte
Digit2 var byte
TrisD = %11110000
TrisA = %01111111
Main:
if PortA.0 = 1 then Count1
else
count2
endif
goto main
END
Count2:
If digit1 > 10 then Deduct
PortD = digit2
Pause 250
Count1:
If Digit1 > 10 then ADd
PortD = Digit1
pause 250
Add:
Digit1 = Digit1 + 1
goto Count1
Is my code, I don't know why whenever i wanna compile it, it says "ELSE without a matching IF .... THEN"
what's wrong with my code?
I use pbp ver2.4
Thanks in advance
If you do if PortA.0 = 1 then Count1 then that is a completed if statement. You need to seperate it to make it work,
Main:
    if PortA.0 = 1 then
        Count1
    else
        count2
    endif
    goto main
END
You also need to remove the END statement or move it to the last line of your file as the compiler will stop compiling at the END statement.
Define osc 4
Digit1 var byte
Digit2 var byte
TrisD = %11110000
TrisA = %11111110
Main:
if PortA.0 = 1 then
Count1
else
Count2
endif
goto main
Count2:
If digit1 > 10 then
Deduct
PortD = digit1
Pause 250
Endif
Count1:
If Digit1 > 10 then
Add
PortD = Digit1
pause 250
endif
Add:
Digit1 = Digit1 + 1
Goto Count1
Deduct:
Digit1 = Digit1 - 1
goto Count2
end
Thanks alot Mike, I changed my code to what u see above, my problem now is that it doesn't read my button and it always counts up. I'd really appreciate it if you could take another look. I really don't know what the problem is and have tried many things. thanks again.
If the "if" expression evaluates to "true" then you call/goto the specified label (not really sure the language you are using). However the code after the label has a "goto" to another label just BEFORE the original "if" statement. This means that you will never get to the code after the first line of the "true" branch.
Simply stepping through the code and pretending you are a computer would show this straight away.
Susan
what is code suppose to do? Is this just a up/down counter? How many buttons are there?
