smallboy404
hello guys !
i'm trying to build a project which is about measurement station , in this project i use a 128x64 glcd (ks0108) . i display menu +sub-mesnu and plot graph.
this project works well on proteus ,and doesn't work well on real hardware .
i use a keypad (4 buttons (up+down+ok+return) to navigate between menus )
the problem is i dont press anything and see changes, random display of menu .
this is a second part of code (menu controle )
glcd_init(on); /
glcd_showimage(&image_9);
while(1){
eta1:
if(input(pin_b1)==1) / RB1 : button "up"
delay_ms(30);
l=l+1; /inc of variable L { from 0 to 3 } i have 4 images .
if(l>3) l=0;
if(input(pin_b2)==1) /RB2: Button "down"
delay_ms(30);
l=l-1;
if(l>3) l=3;
switch(l)
case 0:glcd_showimage(&image_0); / l=0 then show first image .
if(input(pin_b3)==1) / RB3 : Button ok .
s=1;
while(s=1) / button ok pressed then send data via rs232
glcd_fillscreen(0);
glcd_text57(20,10,rs232,1,on);
printf("%f \n\r",current);
printf("%f \n\r",press);
printf("%f \n\r",volt);
printf("%f \n\r",temp);
if(input(pin_b4)==1) { // RB4: Button "return" if its pressed bck to show first image
s=0;
goto eta1;}
break;
case 1:glcd_showimage(&image_1); //l=1 then show second image
if(input(pin_b3)==1) //if ok button pressed
glcd_fillscreen(0);
framevolts(5,0,125,51); //framevolts use to show a frame for plotting
n=1;
while(n=1)
eta2: if(input(pin_b1)==1) // up button pressed
delay_ms(10);
m=m+1;
if(m>4) m=0; / i do same to first menu
delay_ms(10);
m=m-1;
if(m>4) m=4; //
goto eta1;
switch(m)
case 0: glcd_showimage(&image_5);
glcd_fillscreen(0);
glcd_text57(48,57,tmp1,1,on);
s2=1;
while(s2=1)
goto eta2;
draw((int)current*5); //plot variable current .
delay_ms(20);
break;
case 1:
glcd_showimage(&image_6);
glcd_fillscreen(0);
glcd_text57(48,57,tmp,1,on);
s2=1;
while(s2=1)
goto eta2;
draw((int)volt*20);
delay_ms(10);
break;
case 2:
glcd_showimage(&image_7);
glcd_fillscreen(0);
glcd_text57(48,57,tmp3,1,on);
s2=1;
while(s2=1)
goto eta2;
draw((int)press);
delay_ms(10);
break;
case 3:
glcd_showimage(&image_8);
glcd_fillscreen(0);
glcd_text57(48,57,tmp2,1,on);
s2=1;
while(s2=1)
goto eta2;
draw((int)temp);
delay_ms(5);
break;
case 4: glcd_showimage(&image_10);
glcd_fillscreen(0);
s2=1;
while(s2=1)
goto eta2;
delay_ms(20);
break;
break;
case 2:glcd_showimage(&image_2);
break;
case 3:glcd_showimage(&image_3);
glcd_fillscreen(0);
glcd_rect(1,1,125,50,off,on);
delay_ms(20);
glcd_rect(10,10,110,40,off,on);
delay_ms(20);
glcd_text57(3,20,contact,1,on);
delay_ms(20);
glcd_text57(15,52,web,1,on);
delay_ms(800);
break;
glcd_init(on); /
while(1){
eta1:
delay_ms(30);
if(l>3) l=0;
delay_ms(30);
l=l-1;
if(l>3) l=3;
switch(l)
s=1;
glcd_fillscreen(0);
s=0;
goto eta1;}
break;
glcd_fillscreen(0);
n=1;
while(n=1)
delay_ms(10);
m=m+1;
delay_ms(10);
m=m-1;
if(m>4) m=4; //
goto eta1;
switch(m)
glcd_fillscreen(0);
s2=1;
while(s2=1)
goto eta2;
delay_ms(20);
break;
case 1:
glcd_fillscreen(0);
s2=1;
while(s2=1)
goto eta2;
draw((int)volt*20);
delay_ms(10);
break;
case 2:
glcd_fillscreen(0);
s2=1;
while(s2=1)
goto eta2;
draw((int)press);
delay_ms(10);
break;
case 3:
glcd_fillscreen(0);
s2=1;
while(s2=1)
goto eta2;
draw((int)temp);
delay_ms(5);
break;
glcd_fillscreen(0);
s2=1;
while(s2=1)
goto eta2;
delay_ms(20);
break;
break;
break;
glcd_fillscreen(0);
delay_ms(20);
delay_ms(20);
delay_ms(20);
delay_ms(800);
break;
