Bob Parihar
iam doing a project on sms sending through gsm
using SIM 900 module and 8051
My code is:
#include<reg51.h>
unsigned char *command = "AT";
unsigned char *echo = "ATE0";
unsigned char *msgConfig = "AT+CMGF=1";
unsigned char *number = "AT+CMGS=\"8283******\"";
unsigned char *message = "hello";
unsigned char CTRLZ = 0x1A; // now as a variable
void serial_init(void);
void serial(unsigned char);
void puts(unsigned char *p );
void delay(void);
void main()
serial_init();
puts(command);
serial(0x0D); // /r after each command
delay(); // delay of approx 1 sec
puts(echo);
serial(0x0D);
delay();
puts(msgConfig);
serial(0x0D);
delay();
puts(number);
serial(0x0D);
delay();
puts(message);
serial(0x0D);
delay();
serial(CTRLZ); //editing here
while(1);
TMOD=0x20; //timer 1, mode 2(8-bit autoreload) to set baud rate
TH1=0xFD; //-3 to TH1 for 9600 baud rate
SCON=0x50; // 8 bit txion, 1 start 1 stop bit, REN enable for both txfr and rxve
TR1=1; // start timer
void puts(char *p)
char *temp = p; /*temp pointer so that the actual pointer is not displaced */
while(*temp != 0x00)
serial(*temp);
temp++;
void serial(unsigned char x)
SBUF=x;
while(TI==0);
TI=0;
void delay(void) // delay for approx 1 sec
int i;
TMOD=0x01; // timer 0 in mode 1
for(i=0;i<142;i++)
TL0=0x00; // starting value from 0
TH0=0x00;
TR0=1; // sart timer
while(TF0==0); // polling TF flag for high
TR0=0; // stop timer
TF0=0; // clear flag TF0
the problem here is SMS won't send by the GSM
when i use the calling function by replacing the AT commands then calling works
but SMS won't.. i think iam wrong in sending AT commands for SMS... please correct me
My code is:
#include<reg51.h>
void delay(void);
void main()
serial_init();
puts(command);
puts(echo);
serial(0x0D);
delay();
puts(msgConfig);
serial(0x0D);
delay();
puts(number);
serial(0x0D);
delay();
puts(message);
serial(0x0D);
delay();
while(1);
void puts(char *p)
serial(*temp);
temp++;
SBUF=x;
while(TI==0);
TI=0;
int i;
for(i=0;i<142;i++)
TH0=0x00;
