Problem in C coding of 89c51; urgent help required.
I have an error C202: 'P3_3' undefined identifier. What changes should i make in my prog please tell me.
Keil C. Now i am getting error in for loop. It says semicolon before <= and bracket missing but i have put it.
for(tno=1; tno<=no;tno++);
As far as I'm aware, the header file contains the definitions for bit access... You will need to open this file to see them..
I would also need to see your code, as when the C text file is parsed then error may be on a different line... If the line above isn't terminated the compiler will just read on until something doesn't match!!
Unaltered code
C:
#include < stdio.h >
#include < reg51.h >
#include < Delay.h >
sbit INTO = P3 ^ 2;
sbit TRG = P3 ^ 3;
sbit Buzzer = P3 ^ 7;
void Beep(unsigned char No, unsigned int Delay);
void tmrInit(void);
void tmrReset(void);
unsigned int L1 = 100, L2 = 20;
unsigned int T0_ISR_count = 0;
unsigned int US = 0;
unsigned int CM = 0;
void T0_ISR(void) interrupt 1 {
  T0_ISR_count++;
  TF0 = 0;
void main(void) {
  Beep(3, 20000);
  TRG = 0;
  tmrInit();
  while (1) {
    tmrReset();
    TRG = 1;
    DelayI(1000);
    TRG = 0;
    while (INT0 == 0)
      TR0 = 1;
    while (INT0 == 1)
      TR0 = 0;
    US = (unsigned int)((TH0 << 8) | TL0 | ((unsigned int) T0_ISR_count << 16));
    CM = US / 58;
    if ((CM <= L1) && (CM >= L2)) {
      Beep(1, 50 * CM);
    if (CM <= L2) {
      Buzzer = 0;
    } else {
      Buzzer = 1;
    DelayL(2000);
  void tmrReset(void)
  T0_ISR_count = 0;
  TH0 = 0;
  TL0 = 0;
  TR0 = 0;
  void tmrInit(void)
  TMOD = (TMOD & 0xF0) | 0x09;
  unsigned char tNo;
  for (tNo = 1; tNo <= No; tNo++) {
    Buzzer = 0;
    DelayI(Delay);
    Buzzer = 1;
    DelayI(Delay);
Code fixed..
C:
#include<stdio.h>
#include<reg51.h>
#include<Delay.h>
sbit INTO=P3^2;
sbit TRG=P3^3;
sbit Buzzer=P3^7;
void Beep(unsigned char No,unsigned int Delay);
void tmrInit(void);
unsigned int L1=100,L2=20;
unsigned int T0_ISR_count=0;
unsigned int US=0;
unsigned int CM=0;
void T0_ISR (void) interrupt 1
   T0_ISR_count++;
   TF0=0;
void main (void)
   Beep(3,20000);
   TRG=0;
   tmrInit();
   while(1)
     tmrReset();
     TRG=1;
     DelayI(1000);
     TRG=0;
     while(INT0==0)
     TR0=1;
     while(INT0==1)
       TR0=0;
     US=(unsigned int)((TH0<<8)|TL0|((unsigned int)T0_ISR_count<<16));
     CM=US/58;
     if((CM<=L1)&&(CM>=L2))
       Beep(1,50*CM);
     if(CM<=L2)
       Buzzer=0;
     else
       Buzzer=1;
   DelayL(2000);
void tmrReset(void)
   T0_ISR_count=0;
   TH0=0;
   TL0=0;
   TR0=0;
void tmrInit(void)
   TMOD=(TMOD & 0xF0)|0x09;
   unsigned char tNo;
   for(tNo=1;tNo<=No;tNo++)
     Buzzer=0;
     DelayI(Delay);
     Buzzer=1;
     DelayI(Delay);
Please correct the whole code. I am new to this. And there are many errors appearing as i solve 1 nxt appears
It looks to me like you're missing a whole lot of brackets.
Please tell me where.. and is the rest of the code correct??
You need to enclose all of your functions in brackets {}.
For example, here is some of your original code:
C:
 void tmrReset(void)
  T0_ISR_count = 0;
  TH0 = 0;
  TL0 = 0;
  TR0 = 0;
 void tmrInit(void)
 unsigned char tNo;
    Buzzer = 0;
    DelayI(Delay);
    Buzzer = 1;
    DelayI(Delay);
There are three functions there (tmrReset, tmrInit, and Beep), but no brackets to separate them. It should look like this:
C:
 void tmrReset(void) {
  T0_ISR_count = 0;
  TH0 = 0;
  TL0 = 0;
  TR0 = 0;
 void tmrInit(void) {
 void Beep(unsigned char No, unsigned int Delay) {
   unsigned char tNo;
     Buzzer = 0;
     DelayI(Delay);
     Buzzer = 1;
     DelayI(Delay);
Ian Rogers , could you show your edits in a separate post please? I think it would be more useful for Aayesha's original code to be visible, and have your edits shown separately.
Is the DelayI(1000); statement correct or i should give DelayI();
No idea.... The function will be declared in delay.h.... Take a look and see...
Which one
Again... a closing brace.... Before or after the delay statement!!
I think I slipped it in the wrong place as the delayL(2000) is superfluous now...
Looking at the code I would say delayI() is for integer variables and delayL() is for longs... so delayI() wouldn't be used as there is no parameter...
