Gabe Billings
I have an electromagnetic door lock and I don't quite understand how different power input will affect it. The instructions that came with it note that it can be used at either 12V or 24V, drawing 500mA or 250mA respectively.
First off, I don't understand the dual voltages. There's nothing in the instructions or a visible way to switch from one to the other. Is it just simply a question of using one input power or the other, without having to actually 'do' anything to the magnet?
If that's the case, is there anything wrong with using a voltage between those values? I have an old laptop power supply that's 15V/5A that I'd like to recycle, assuming I can use it without anything catching on fire.
I hooked it up and checked it with my multimeter and it's drawing 360mA. Seems to be working as it should.
So, anything wrong with using this power supply?
