Concept: Regulate 48vdc input to 13.5vdc output using 1 or 2 LM2596HVS step-down modules (no heat-sinks) to provide at least 2.0A constant current out @12v.
Problem: Probability of smoke -- Unknown to this novice.
LM2596HVS module specs: 5-55vdc in, 3-48v out @2.4A (3A max with HS) ~ probably overstated
Output voltage adjustable but current adjment is unknown (has 2 multi turn pots but 2nd one may only be for charging threshold LED)
Can be connected in series for better efficiency - Is this true?, does it matter?
No external components required.
Use: Power source and battery charger.
Constraints: Limited space for components, no room for heat-sinks, limited ventilation.
Other: Minimum wire gauge?
Input power switch min. rating?
Info and recommendations are highly appreciated,
