PORTB interruption with CCS Compiler ?
loup-garou
Hello all,
My code which consists on lightening a LED connected to RA3 with a push-button connected to RB6 was compiled with success (0 error , 2 warnings of conditions always true and false) but did no function when I tried to simulate it with ISIS however it was a simple one (see below),
would anybody help me in correcting it or give me another correct code written with the same compiler ?
thanks in advance.
I use PCW 4.057 version of CCS.
#include "C:\Documents and Settings\test 1.h"
  #ZERO_RAM
#define RB6 PIN_B6
int1 flag6;
#int_RB
void RB_isr()
if (!RB6) flag6=1;
delay_ms(300);
void main()
   port_b_pullups(TRUE);
   setup_adc_ports(NO_ANALOGS);
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_8);
   setup_timer_1(T1_DISABLED);
   setup_timer_2(T2_DISABLED,0,1);
   ext_int_edge(H_TO_L);
   enable_interrupts(INT_EXT);
   enable_interrupts(INT_RB);
   enable_interrupts(GLOBAL);
   set_tris_b(0xff);
   set_tris_a(0x00);
 flag6=0;
while(1)
  if (flag6)
     output_high(pin_a3);
     flag6=0;
kchriste
Forum Supporter
You shouldn't have a delay in an interrupt routine. You could do this without using interrupts. Which PIC are you using?
kchriste
Forum Supporter
I don't use that compiler but, you need to clear the RBIF bit in the INTCON register at the end of the interrupt routine. It is also recommended that you read from portB and then clear the RBIF bit in the INTCON register when you initialize the PIC.
Pommie
Most Helpful Member
AFAIA, the CCS compiler clears the interrupt flag for you. Whether it reads portb as well I can only guess but portb must be read before clearing RBIF in the ISR. I don't like compilers that help me in that way.
loup-garou
I found in CCS Manual this interruption relevant functions:
disable_interrupts() : Disables the specified interrupt.
enable_interrupts() : Enables the specified interrupt.
ext_int_edge() : Enables the edge on which the edge interrupt should trigger. This can be either rising or falling edge.
clear_interrupt() : This function will the specified interrupt flag. This can be used if a global isr is used, or to prevent an interrupt from being serviced.
so I wrote clear_interrupt(RB6) in the end of the interrupt routine but this did not make any change, is this correct ?
#int_RB
void RB_isr()
if (!RB6) flag6=1;
clear_interrupt(RB6);
Pommie
Most Helpful Member
Yes, the read of RB6 will clear the mismatch but I would guess that the function should be clear_interrupt(RBIF).
As 3v0 states look at the asm if your unsure.
loup-garou
When in doubt about what the compiler is doing look at the generated ASM code in MPLAB. VIEW>DISASSEMBLY_LISTING
unforunatly, I don't understand well ASM, I've never programmed with this language.
but thank you for the advice.
3v0
Coop Build Coordinator
Forum Supporter
unforunatly I don't understand ASM.
This is a good time to get started. Look up each opcode in the data sheet for the processor family. You do not have to understand every detail this time, just identify where the interupts are cleared and disabled/enabled.
Everyone should learn assembly at least to the point where he understands what the compiler is doing.
loup-garou
thank you 3V0 !! ;)
LUNAR
PIC18F4550 interrupt HELP PLEASE
HELLO i am using pic18f4550, i just want to configure the int0 to blink and led, but i am not having any luck please see my code and tell me where i am wrong. i am really stuck. thanks.
//test code for int0, blink led on portD on receving interrupt
#include <p18f4450.h>
void main (void);
void InterruptHandlerHigh (void);
void main ()
int i=0;
INTCON2bits.INTEDG0=1;//m interrupt is rising edge
INTCONbits.INT0IE=1;//m enable interrupt
INTCONbits.GIEH = 1; //enable global interrupts
TRISB = 1; //set port b as input
TRISD=0; //set port d as output
while(1);//move in loop, gets out on receving interrupt and then comes back.
}//end main
// High priority interrupt vector
#pragma code InterruptVectorHigh = 0x08
void
InterruptVectorHigh (void)
_asm
goto InterruptHandlerHigh //jump to interrupt routine
_endasm
// High priority interrupt routine
#pragma code
#pragma interrupt InterruptHandlerHigh
void
InterruptHandlerHigh ()
{ int i=0;
int j=0;
if (INTCONbits.INT0F)
INTCONbits.INT0IE=0;//m disable the interrupt
for(j=0;j<4;j++)//toggle the bit0 or portD on receiving interrupt
LATDbits.LATD0 = 1;
for( i=0;i<40000;i++);
LATDbits.LATD0 = 0;
INTCONbits.INT0F=0; //m reset the flag
INTCONbits.INT0IE=1;//m enable the interrupt
futz
Active Member
Hey Lunar. If you can, start a new thread of your own. And when you post code, always use the Code tags. To do this, click on the # symbol in the posting menu just before pasting your source code. You can also do it by typing [code] before your source and [/code] after it. This preserves the formatting of your source code so it stays readable and people will actually look at it.
Like this:
void main()
	int i=0;
	INTCON2bits.INTEDG0 = 1;	//m interrupt is rising edge
	INTCONbits.INT0IE = 1;		//m enable interrupt
	TRISD = 0;			//set port d as output
	while(1);	//move in loop, gets out on receiving interrupt and then comes back.
void InterruptVectorHigh(void)
	_asm
	_endasm
// High priority interrupt service routine
#pragma code
void InterruptHandlerHigh()
	int i=0;
	int j=0;
	if(INTCONbits.INT0F)
		INTCONbits.INT0IE=0;	//m disable the interrupt
		for(j=0;j<4;j++)	//toggle the bit0 or portD on receiving interrupt
			LATDbits.LATD0 = 1;
			LATDbits.LATD0 = 0;
	INTCONbits.INT0IE=1;		//m enable the interrupt
EE World Online Articles
Loading
