Hook a load resistor (about 1K) from collector to negative supply set to ~10V.
Hook positive supply to emitter, call that ground.
Hook base to neg supply through a 47K current limiting resistor.
The collector should switch from ground to negative as the base resistor is connected/disconnected.
If it works, the β is at least 47K/1K.
