I have a simple question, and if you want to just answer yes or no, thats fine... I would love to learn if there is anybody that wants to take the time to teach.
Thanks in advance.
I am looking to make some battery packs to power my RC car. It is a Traxxas 1/16 scale E-Revo VXL if you want to get some specs on it, but I think what you need to know, I will have posted below.
The Factory battery packs are 6 Cell packs of 2/3A 1200mAh cells at 7.2V. There is room to run two packs in the car and the Electonic Speed Control can handle up to 14.4V if you run two packs in series.
The Packs I want to make would be 4 Cell packs of Double A (AA) 2500mAh at 4.8V and run them in series for 9.6V (space is an issue...)
What I am wondering though is: Will the (AA) cells be able to handle the current that the 2/3A cells can?????? or am I just going to fry the (AA's) after a few charges??
here are the specs that you may want to look at to answer...
Electronic Speed Control Specs:
Input Voltage: 6 to 12 cells NiMH, 2S to 3S LiPo
Case Size: 26.5mm W x 46.5mm D x 22mm H
Weight: 38 grams
Motors: Sensorless Brushless
Motor Limit: None
On Resistance: 0.0005 Ohms
PWM Frequency: 12,000Hz
Peak Current: 326A
Continuous Current: 52A
BEC Voltage: 6.0V DC
Motor / Battery Wiring: 16-Gauge Maxx® Cable
Transistor Type: MOSFET
Low Voltage Detection: 2-Stage indicators, switchable (on or off)
Thermal Protection: 2-Stage thermal shutdown
Single-button setup: Yes, Traxxas EZ-Set®
Battery Input Connector: Traxxas High-Current Connector
Motor Connector: TRX 3.5mm Bullet Connectors
Brushless Motor Specs:
Type: Sensorless Brushless
kV (RPM/Volt): 4000kV (8T)
Magnet Type: High Temp Sintered Neodymium
Connection Type: TRX 3.5mm Bullet
Wire Size: 16g Maxx Cable
Continuous Current: 25A
Max Current: 50A Burst
Max RPM: 50,000
Weight: 140g (4.94oz)
Here are the cells that I bought to make these packs...
https://www.all-battery.com/aa2500mahhighcapacitynimhrechargeablebattery10320.aspx
Thanks again.
Thanks in advance.
Weight: 38 grams
Motor Limit: None
Peak Current: 326A
Max RPM: 50,000
Thanks again.
