Please critique my PWM code!
bsodmike
Here is the code:
	list p = 16F84A
	org	00h		; the reset vector is defined as address 00hex
   	goto	setup		; and we tell it to go to 'setup'
;.......Variables..........................................................
	cblock	0Ch
 	half_t
	sum
	sample1
	overflow
	cnt
	endc
;.......Equates............................................................
w	EQU	00h
_tmr0	EQU	01h
_status	EQU	03h
_option	EQU	01h
_portb	EQU	06h
;=======Subroutines========================================================
;~~~~~~~Delay Loop~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
delay	clrf	_tmr0		; Start tmr0
dloop	movf	_tmr0,w		; Read tmr0 into w, w holds time
	subwf	half_t,w	; half_t - tmr0
	btfss	_status,2	; Check half_t - tmr0 = 0
	goto	dloop		; result is not 0
	retlw	0		; they are equal, return
freq	bsf	_portb,0		; Output high...
	call	delay		; for duration of 'half_t'
	bcf	_portb,0		; Output low...
	retlw	0
setup	bsf	_status,5	;move into bank 1
	movlw	b'00000000'	;porta as output
	movwf 	_portb		;
	movlw	b'00000101'	;prescaler is /64
	movwf	_option		;
	bcf	_status,5	;back to bank 0
	clrf 	_portb		;clears porta
begin	bsf	_portb,1
	movlw	.37
	movwf	half_t
	call	freq
	goto	begin
	end
And the output:
As you can see the Duty cycle increases as the frequency goes up. This is due to a 'small' error in the 'delay' loop.
This is how I am calculating the PWM:
Clock Speed: 4 Mhz
Program Speed: 4 Mhz/4 = 1 Mhz
TMR0 prescaler: 1 Mhz/64 = 15625 hz
Time for one TMR0 pulse is 1/15626 = 64µs
To measure the time for 100 hz let us consider the following:
1/100 = 0.01s ; 0.01/64µs = 156 TMR0 pulses.
Check: 1/(100*64µs) = 156
Therefore the 50% duty cycle is achieved by performing the following:
• Set output high
• Count TMR0 such that it is 156/2 (which is 50hz)
• Set output low
The above example will create a 100 hz signal with a duty cycle of 50%
NOTE!
   movlw   .37
   movwf   half_t
   call   freq
The .37 is the PWM loading value, it defines the on/off time. 37*2 = 74 ; 15626/74 = 211hz
As I am clearing tmr0 this takes another extra cycle per clearing? If so, this means on the 'on' it is 38*2 = 76 and on the off another 76 - this still does not explain the duty cycle skew....
Update - 15:43 +5GMT: I changed the TMR0 scaler to 1/32. This gives 31250/105 = 298 counts, but as I am only counting half - 149!
As I mentioned before, this comparing tmr0 and W is a strange way to do the delay - for a start it gives you two unnecessary instructions (movf and subwf) during the timing loop. By loading tmr0 with 255 minus the value you require (and also taking account of the 2 instruction cycles lost while writing to tmr0), you only need to check the tmr0 overflow flag.
Doing it this way would reduce your delay 'jitter' time by at least 2uS, and make your code shorter as well.
Ahh now I understand.
**removed
The freq calling loop:
	movfw	half_t
	movwf	cnt
	movfw	half_t
	movwf	cnt
	retlw	0
Had to waste 2 cycles before the loop as I want to reuse 'half_t' once the first delay finishes....
What do you think?
This is the sort of routine I'm talking about, simply load W with the value you want, and 'call Delay' - bear in mind the timer will count upwards from this value till it overflows, so 245 would give a delay of 11 - or 200 would give a delay of 56 - the smaller the value, the longer the delay.
Delay	MOVWF	TMR0		;load TMR0 from W
	BTFSS	INTCON, T0IF	;wait for overflow
	GOTO	$-1
	RETURN
Ahh okay!
delay	movwf	_tmr0		; load this to the timer
d1	btfss	_intcon,2	; if tmr0 overflow is not set
	goto	d1		; loop, else skip
	bcf	_intcon,2
	retlw	0		; cnt = 0, so return
cleared the overflow flag on leaving the delay (so that for subsequent delays it will not affect them)
Thanks Nigel!
Update 23:33 +5GMT: Tested the following 16F84A code:
	list p = 16F84A
	cblock	0Ch
	pulsewidth
	sum
	sample1
	overflow
	cnt
	endc
w	EQU	00h
_tmr0	EQU	01h
_status	EQU	03h
_option	EQU	01h
_intcon	EQU	0Bh
_portb	EQU	06h
	bcf	_intcon,2
	return			; cnt = 0, so return
	retlw	0
	movwf 	_portb		;
	movlw	b'00000100'	;prescaler is /32
	movwf	_option		;
begin	movlw	.182
	call	freq
	goto	begin
	end
Now it is varying from 50.15% to 50.30%...... :? :? :(
All this means is that the on delay is lasting a tad longer thant he off...I'm at a loss in spotting this..hrm!
Maybe I should do this:
delay   btfss   _intcon,2   ; if tmr0 overflow is not set
        goto   delay        ; loop, else skip
        bcf   _intcon,2
freq   movwf   _tmr0        ; load this to the timer
       retlw   0
Doing it this way does this:
105hz - 50.14%
210hz - 50.28%
Any tips?
	bcf	_intcon,2
	return			; return
	call	delay		; for duration of '256-w'
	retlw	0
Perhaps you don't realise, but you're worrying about less than 1% change, as reported by your meter - who's accuracy probably won't be as high as that.
I shouldn't worry about it!.
Gotcha... :lol: My requirement is between 49-51% dutycycle but I'm just trying to see how close to 50% dead on I can get it ;)
But your meter is only so accurate, you're already closer than the meter can distinguish. Polling TMR0 is always going to give a slight variation, the few microseconds where you test the flag is always going to vary, depending on the exact instant the timer overflows. You could always use interrupts to try and prevent this, or (even easier) use simple software loops - where it takes exactly the same time every time.
Wy is it normal to overflow???
i mean doesn't that take some more cpu time and fault corrections..??
TKS
Re: ..
It's not a fault, it's simply the timer looping round, it's an eight bit timer, so when it gets to 255 (0xFF) on the next clock it overflows and loops back to zero. This overflow sets a flag that you can check, and also initiates an interrupt - if it's set to do so.
