Piezo transducer complication
I am using a piezo transducer and I would like to make it somewhat more sensitive somehow or any other way of fixing this:
Problem: Piezo works when I tap it with my finger however it does not do anything when it is tapped by a metallic object which is hitting it with less cross sectional area however with the same force. in application the piezo is meant to be hit by a metallic object and not my finger, any ideas?
Is there something I'm missing ?
Thanks for your help, any ideas are welcome!
OK.
Some additional info would be nice, i.e.,
-Piezo specs
-How is piezo mounted
-Peizo output level when tapped with your finger
-Peizo output detection method
-What is the metallic object.
Anything else that helps describe your circuit.
Perhaps the piezo output is being short-circuited via the metal and your body? You could test this hypothesis by providing an insulation layer between metal and body.
It works when the anode and cathod wires e of the piezo are in a certain position so I guess I have to keep it in that position..
JM, I'd be interested in seeing a picture of what you described in the post above.
Just curious...
Is the amplifying/sensing circuit input impedance of the proper MΩ magnitude ?
Is it a round sensor with a white patch on one side and two wires on the side of the white bit? If so turn it over ;)
Sorry that was rubbish description! is it like this kind of sensor?
If so they work better if you turn them over to the plain metal side and bang that :D
Yep that's it.
Isn't it the piezo material which is tapped that makes it work and the brass around it is for conduction ?
so technically you need to tap the piezo material rather than the metal?
I found the white bit gets damaged, mine have seemed to work better if i tap the back (the bronze bit).
