PIC18F UART Issue
AtomSoft
All i get is gibberish... or HIGH values like 0xE0 or higher...
Im going for a 40MHz using PLL and a 10MHz OSC... Its not a hardware problem as i had this board working before using some other code... (LOST)
So am i setting this all up ok? Any Thoughts?
Im trying for 19200bps 8-N-1
Thanks Guys/Gals :)
#pragma config OSC = HSPLL, BOREN = OFF, WDT = OFF, MCLRE = OFF, LVP = OFF, XINST = ON
/* User Global Variable Declaration                                           */
/* Main Program                                                               */
void main(void)
    unsigned char var;
    /* Configure the oscillator for the device */
    ConfigureOscillator();
    /* Initialize I/O and Peripherals for application */
    InitApp();
    /* TODO <INSERT USER APPLICATION CODE HERE> */
    while(1)
        var = getChar();
void ConfigureOscillator(void)
    // 40MHZ - 10MHZ * 4xPLL
    OSCCON = 0;                 //Primary OSC Selected
    while(!OSCCONbits.OSTS);    //Wait until Primary OSC is ready and running
    ADCON0 = 0;
    ADCON1 = 0x0F;
    CMCON = 0x07;
void InitApp(void)
    //Enable UART 19200,8-N-1
    RCSTAbits.SPEN = 1;
    TRISC |= 0b11000000;
    SPBRG = 129;
    TXSTA   = 0b00100100;
    BAUDCON = 0b00000000;
    RCSTA   = 0b10010000;
    PIR1 = 0;
unsigned char getChar(void)
    unsigned char rxTemp = 0;
    while(PIR1bits.RCIF == 0);
    rxTemp = RCREG;
    return rxTemp;
Oops sorry ... Its a PIC18F4620
It triggers fine when i send a character but just not right data, im sure it has to be either osc settings or uart settings... But i cant see the problem :(
It looks fine to me. Do you have a max232 fitted as that chip can work without one.
Them crystals get you every time I married one she took me to the cleaners LOL
Back to this crystal osc I've cooked some myself.
Hi Atom, as a simple test you can send out 0x00 out the USART repeatedly with a pause between, and it will make a period of 9 LOW bauds which looks like a single LO period on the 'scope.
Assuming you have a 'scope you just probe the TX pin and can see instantly what the baudrate is as it will be the LO period divided by 9. It's a quick and reliable test that can save heaps of messing in code checking setups. :)
