PIC16F877 interface with RS232 program
winsthon
hi, anybody who can help me, im doing this project using PIC16f877 and I want to interface it to my PC using RS232. I've visited www.winpicprog.com and constructed the circuit. my problem is I dont know how to begin the program, I dont know how to send the data from my PIC to my PC. anyone who can help me. By the way my project is color recognizer using PIC16f877 wherein the output will be printed on the LCD...additional feature is to interface it with RS232 on my PC and display the output at my PC. Can anyone give me an idea or even a program to get me started? I appreciate you help...
I didn't see this until after I'd replied to the first one :D
I just use Hyperterminal to display data at the PC end, just sending ASCII characters and CR/LF - as long as you only need a straight text display that's all you need to do.
hi winsthon
did yoy complete your this project?I need same of this I will data logger by using pic16f877 when data came from inputs pic will send the data to my pc can you help me about designing circuit?
Avoid hyperterminal:**broken link removed**
An example rs232/usb for the PIC: **broken link removed**
Use C: **broken link removed**!
LIST P = PIC16F877A ;declares the chip to be used
#INCLUDE "P16F877A.INC" ;Includes for resolving the
;SFR locations of this particular chip
__CONFIG _CP_OFF & _WDT_OFF & _XT_OSC & _LVP_OFF
;This directive sets the configuratuion
;bits of the controller
; DEFINES
LEDEN EQU .01 ; for enabling LED array ON PORTC
LATCH EQU .00 ; for latching the relays ON PORTC
BUZZER EQU .05 ; buzzer on RB5 of PORTB
DIG1 EQU .03
DIG2 EQU .02
DIG3 EQU .01 ; Seven segment digit enable transistors on these
DIG4 EQU .00 ; PORTB pins
;GENERAL PURPOSE REGISTERS
cblock 20h
wait_cnt ; variable which holds the timing
delay_var1
delay_var2 ; For PIC16F877A RAM starts from 20H adress.
delay_var3 ; variables used for delay generation
digit1
digit2 ; These 4 vriables hold the value to be displayed in each digit
digit3 ;
digit4
rxtemp ; temparary holder of received data
stringcnt ; variable used to count the postion index of string to be transmited
endc
;***********************MAIN PROGRAM*******************************************
; reset location of the PIC, Execution starts from here.
ORG 0X00 ; RESET VECTOR
MOVLW 00H
MOVWF PCLATH
CLRF STATUS ; INITIALISE BANK AND PAGES
GOTO start ; jump to the programe area
org 04h
retfie ;This part takes care of the intrupt locations
;Interupts are not enabled ,but to make sure....
look_up ; This subroutine should be placed within the botton 255 locations of PIC programe memmory- like this!
;This subroutines returns the segment pattern of
addwf PCL,F ;digit to be displayed
retlw b'00111111' ;'0'
retlw b'00000110' ;'1'
retlw b'01011011' ;'2'
retlw b'01001111' ;'3'
retlw b'01100110' ;'4'
retlw b'01101101' ;'5'
retlw b'01111101' ;'6'
retlw b'00000111' ;'7'
retlw b'01111111' ;'8'
retlw b'01101111' ;'9'
retlw b'00000000' ; This is for blanking a digit if required
id_string ; This lookuptable will return the string to be send to PC on 'a' Command
addwf PCL,f
DT " This is 'MICROMASTER' from Microcode Solutions;connected"
DT " in the communication port of your system",0Dh,0Ah,0
salute_string ;; This lookuptable will return the string to be send to PC on 's' Command
addwf PCL,f
DT " You are learning Serial port usage? "
DT " All the best",0Dh,0Ah,0
start
call ports_ini ;call the subroutine to configure the ports as input or output
call board_ini ;configure the peripherals to avoid unwanted current drain
call var_ini ;initialise all the required variables.
call usart_ini ;initialises the onboard serial port of PIC
goto mainline ;goto mainline of the programe
mainline
btfss PIR1,RCIF ; check weather any data received from serial port
goto xx ; if no just go and do the display
bcf PIR1,RCIF ; if yes process the data received
movfw RCREG
movwf rxtemp ; copy to a temparary register
movfw rxtemp
xorlw 'a'
btfsc STATUS,Z
call id_send ; if the received letter is 'a' send this string
movfw rxtemp
xorlw 's' ;if the received letter is 's' send the following string
btfsc STATUS,Z
call salute_send
xx call sevsegdisp ; this routine handles the seven segment display
goto mainline ;
;Here onwards functions for the programe
id_send
clrf stringcnt ; clear the counter
loopagn movfw stringcnt ;take the count in working register and call string table
call id_string ; returns with the letter to send
xorlw 00h ;check weather it is 0
btfsc STATUS,Z ; if 0 return
return
call transmit ; else transmit the letter
call sevsegdisp
incf stringcnt,f ; repeat this to send the entire string
goto loopagn
salute_send
clrf stringcnt
loopagan movfw stringcnt
call salute_string ; just do as the previous string
xorlw 00h
btfsc STATUS,Z ; only the text changes
return
call transmit
call sevsegdisp
incf stringcnt,f
goto loopagan
usart_ini
bsf STATUS,RP0 ;switch to bank1
bsf TRISC,6 ; as per datasheet these pins have to be made input .
bsf TRISC,7
clrf TXSTA ; TXSTA=0
movlw .25 ; SPBRG = .25 for baud9600(Datasheet)
movwf SPBRG
bsf TXSTA,TXEN ; TXSTA.TXEN=1 -TRANSMIT ENABLE
bsf TXSTA,BRGH ; High speed
bcf PIE1,TXIE ; PIE1.TXIE=0 -NO INTS
; bsf PIE1,RCIE ;receive interupt enabled
bcf STATUS,RP0 ; back to bank0
bsf RCSTA,SPEN ; RCSTA.SPEN=1 -RC.6 ANS RC.7 FOR SCI
bcf RCSTA,RX9
bsf RCSTA,CREN ; continius receive enabled
return
transmit
; this routine transmits a 8 bit data
movwf TXREG ; TXREG=trans_data; // 8BIT DATA
clrwdt
btfss PIR1,TXIF ; wait until transmition complete to return
goto $-2
return
sevsegdisp ;This handles seven segment display
movfw digit1 ; using the method of digit multiplexing
call look_up
movwf PORTD ; Segment pattern of digit1 to PORTD
bsf PORTB,DIG1 ; Select digit1
call delaySs ; Wait for a small delay
bcf PORTB,DIG1 ; off this digit
movfw digit2 ; pattern of digit2 to PORTD
call look_up
movwf PORTD
bsf PORTB,DIG2 ; enable second digit
call delaySs ; keep it glowing for some time
bcf PORTB,DIG2 ; off it
movfw digit3
call look_up
movwf PORTD ; patern for digit3
bsf PORTB,DIG3
call delaySs
bcf PORTB,DIG3
movfw digit4 ; pattern of digit4
call look_up
movwf PORTD
bsf PORTB,DIG4
call delaySs
bcf PORTB,DIG4 ; when this repeated glowing of each digit at high speed
return
var_ini movlw .0
movwf digit1
movwf digit2 ; clear all digit values to avoid garbage display
movwf digit3
movwf digit4
clrf wait_cnt
return
ports_ini
bsf STATUS,RP0 ;select bank1 for tris registers
bcf TRISC,LEDEN ;make the transistor driving pin output
bcf TRISC,LATCH ;make the relay latching pin output
movlw b'00000000'
movwf TRISD ; make all portd as output
bcf TRISB,BUZZER ; enable buzzer line as output
movlw b'11110000' ; make all digit selecting pins output
movwf TRISB
bcf STATUS,RP0 ;back to bank0
bcf PORTC,LATCH ;pull the latch pin low
bcf PORTC,LEDEN ;keep led array off
bcf PORTB,BUZZER ;switch off buzzer
movlw b'11110000' ;Clear all the digit selecting ..
andwf PORTB,F ;transistors
return
board_ini
bsf STATUS,RP0
movlw b'10000100' ; These settings are done for the board components
movwf ADCON1 ; not to interfere- not a part of this lesson.
movlw b'00001011'
iorwf TRISA,F ; analogue input with Vdd as Vref
bcf TRISA,2 ; Make sure This is output.
bcf STATUS,RP0
clrf PORTD ;clear the lines to switch of the relays.
bsf PORTC,LATCH ;enable and disable the control line.
bcf PORTC,LATCH ;latched!(relays off)
bcf PORTA,2 ; keep Disabld the LCD module.
return
delaySs ; This routine creates a small delay(7mS) of processor
movlw .2 ; time enough to elude our persistence of vision .
movwf delay_var1
out_loop decf delay_var1,f ; outer most loop variable
btfsc STATUS,Z
return ; when all variables are 0 delay returns !
movlw .40
movwf delay_var2
midle_loop decf delay_var2,f ;midle loop variable
btfsc STATUS,Z
goto out_loop
movlw .35
movwf delay_var3
inner_loop decf delay_var3,f ;inner most loop
btfsc STATUS,Z
goto midle_loop ; total delay = (innerloop*middleloop*outerloop)time
goto inner_loop
end ; end directive to assembler
this is an exmple program........for rs232 interface
