PIC16f877 ADC conversion clock period
Ian,
Do you think that i need to make a counter diferent to TMR0? The problem is that "DELAY" value is not always the same? could you give some help to continue?
Thank you.
You need to interrupt with INT0..... then ONLY set the timer length and set the timer0 interrupt (turn the INT0 interrupt off) when the timer overflows THEN set the INT0 parameters
So... flow
interrupt
   if INT0IF
      turn off INT0IE
      set TMR0
      set TMR0IE
      clear TMR0IF
      goto to retfie
   else
      turn off TMR0IE
      do stuff now
      set INT0IE
      clear INT0IF
   end if
retfie
Sort of like that
Thank you so much,
I write your code in assambler as:
INT
	BTFSS INTCON, INTF
	GOTO OTROCASO
	BCF	INTCON, INTE
	MOVF DEMORA, W
	MOVWF TMR0
	BSF INTCON, INTE
	BCF	INTCON, T0IF
BACK
		RETFIE
OTROCASO
	BCF INTCON, INTE
	MOVLW B'00000010'	; TRIGGERING  TRIACS
	MOVF PORTB
	BSF INTCON, INTE
	BCF INTCON, T0IF
	GOTO BACK
Should work?
INT
	BTFSS 	INTCON, INTF
	GOTO 	OTROCASO
	BCF	INTCON, INTE
	MOVF 	DEMORA, W
	MOVWF 	TMR0
	BSF 	INTCON, T0IE
	BCF	INTCON, INTF
BACK
	RETFIE
OTROCASO
	BCF 	INTCON, T0IE
	MOVF 	PORTB
	BSF 	INTCON, INTE
	BCF 	INTCON, T0IF
	GOTO 	BACK
This seems to work...
Ian (I'm back, ;-) ),
After building pcb and run the program, interruption routine doesn't work fine. If i don't interrupt the pic, the main program run ok, but if I invoke the interruption, the sistem will be block, it seems not to go out from interruption. can you take a look to my code?
	PROCESSOR 16F877	; define tipo de procesador
	__CONFIG	0x3731	; 4Mhz frecuencia de reloj, standard fuse
	#include <p16F877.inc>	; Etiquetas de registro estandard
; Registra etiquetas EQU
STATUS	EQU	0x03
PORTA	EQU	0x05	; Registro de datos del puerto A
PORTB	EQU	0x06	; Registro de datos del puerto B
PORTC	EQU	0x07	; Registro de datos del puerto C
PORTD	EQU	0x08	; Registro de datos del puerto D
TRISA	EQU	0x85	; Direccion del registro puerto A
TRISB	EQU	0x86	; Direccion del registro puerto B
TRISC	EQU	0x87	; Direccion del registro puerto C
TRISD	EQU	0x88	; Direccion del registro puerto D
ADCON0	EQU	0x1F
ADCON1	EQU 0x9F	;
ADRESH	EQU	0x1E
TMR0	EQU	0x01	; Registro de tiempo hardware
INTCON	EQU	0x0B	; Registro de control de interrupcion
OPTREG	EQU	0x81	; Registro de opciones
st_pers	EQU	0x20	; Var para control del estado de la persiana
st_LigH	EQU	0x21	; Var para control del estado de la luz
comp1	EQU	0x22	; Var resultado comparador 1
comp2	EQU	0x23	; Var resultado comparador 2
Lampara	EQU	0x24	; Luminosidad de la lampara 0=baja..127=maxima
result	EQU	0x25	; Var para almacenar resultado comparacion.
estado	EQU	0x26	; Var para estados d las var XXXX X pers sint sext
count1	EQU	0x27	; Var para el contador de delay
count2	EQU	0x28	; Var para el contador de delay
W_Temp	EQU	0x29	; Guardamos registro W durante interrupcion
St_Temp	EQU	0x30	; Guardamos registro STATUS durante interrupcion
ls_adc	EQU	0x31	; Guardamos el valor despues de la conversion AD
DEMORA	EQU	0x32	; Valor de demora para enceder el TRIAC
PDel0	EQU	0x33	; Variable para el calculo de 5segundos de retardo
PDel1	EQU	0x34	; Variable para el calculo de 5segundos de retardo
PDel2	EQU	0x35	; Variable para el calculo de 5segundos de retardo
Contador EQU 0x36	; Variable para el retardo de 20us
	ORG 	000		; Comienzo de la memoria del programa
	NOP				; Para el modo ICD
	GOTO 	init	; Salta al programa principal
	ORG		04
	GOTO	INT
; Inicializacion del puertos ..................................................
init
	BCF	STATUS,7	; Configure  bit FSR a 0 to work with bank0/1
	BCF	STATUS,5	; Selecct bank0 RP0
	BCF	STATUS,6	; writing 00 en RP0:RP1
	BCF	estado,2	; Initial state to shade (blind) as closed
	BCF	estado,3	; After 5 seconds running up PORTD, this flag will be active
	CLRF	PORTA		; cleaning PORTs A al D
	CLRF	PORTB
	CLRF	PORTC
	CLRF	PORTD
	BSF	STATUS,5	; Selectbank 1 writing 01 RP0:RP1
	MOVLW	0X80		;
	MOVWF	ADCON1		; PORTA as analogic
	MOVLW	0XCF		;
	MOVWF	TRISA		; PORTA as input
	NOP			; BANKSEL no puede ser etiquetada
	BANKSEL	TRISB		; Select bank1
	MOVLW	b'11111101'	; Configure RB1 as output(b'11111101') 253
	MOVWF	TRISB		; Load code DDR en F86
	BANKSEL	TRISC		; Select  bank1
	MOVLW	b'10111111'	; Configure RC6 as output and RC7 as input(b'01111111') 127
	MOVWF	TRISC		; Carga el codigo DDR en F87
	BANKSEL	TRISD		; Select bank1
	MOVLW	b'11111111'	; Configure PORTD as output(b'11111100') 252
	MOVWF	TRISD		; load  DDR en F88
	BANKSEL	TRISE		; Select bank1
	MOVLW	b'00000000'	;  bit4 a 0 to use portd as general port
	MOVWF	TRISE		;
	MOVLW B'11000111'	; PRESCALER assigned to TMR0
	MOVWF OPTION_REG
	MOVLW B'10010000'	;INT PIN RB0
	MOVWF INTCON
	BANKSEL 0
;	MOVLW B'00000000'
;	MOVF DEMORA
	GOTO	Ppal
INT
	BTFSS INTCON, INTF
	GOTO OTROCASO
	BCF	INTCON, INTE
	MOVF DEMORA, W
	MOVWF TMR0
	BCF	INTCON, T0IF
	BSF INTCON, INTE
BACK
		RETFIE
OTROCASO
	BCF INTCON, INTE
	MOVF PORTB
	BCF INTCON, T0IF
	BSF INTCON, INTE
	GOTO BACK
;Programa principal
Ppal
	CALL	Capdat	; Adquiring data subroutine
	CALL	nivluz1	; subroutine for managing delay for dimmer
	CALL	persia	; Acting on shades or blind
	GOTO	Ppal
;Subrutina de captura de datos.................................................
; getting data from LDR to manage light intensity
; Init conversion AD. Clock conversion 4MHz/32,AN4 Channel ON
; AN0,AD conversion OFF,AD module de conversion ON
Capdat
		banksel ADCON0
		movlw b'01000001'    ; fosc 8, RA0 analogico
		movwf ADCON0
; Incializacion convertidor AD. left-aligned, All PORTA as analog input
 	banksel ADCON1
 	movlw b'00001110'	;left-aligned,  channel 0, module ON
 	movwf ADCON1
	call Demora_20us	; Waiting adq time
; Starting conversion AD
 	banksel ADCON0
 	bsf ADCON0,2
; waiting for conversion end
espera
	btfsc ADCON0,2
	goto espera
; Writing value at reg named ls_adc.
	banksel ADRESH
	movf ADRESH,0       ; Working with ADRESH only
	banksel ls_adc
	movwf ls_adc        ; valor en W Reg. se escribe en la variable ls_adc
	RETURN
Demora_20us
	movlw 0x05
	movwf Contador		; init Contador for delay
Repeticion
	decfsz Contador,1	; Decrementa Contador en 1
	goto Repeticion		; Si no es cero repetimos el ciclo
	RETURN
;;Tratamiento de los datos, comparativa de niveles de luz.......................
nivluz1
	MOVLW 	b'11100101'	; load value to compare level with stimate 4,5V
	SUBWF 	ls_adc,W	; compare ls_adc with ref value
	BTFSC	STATUS,Z	; If match run following line, opposite jump next line
	GOTO	dem10ms
	BTFSS	STATUS, C	; check bit to know if is greater or lesser
	GOTO	nivluz2		; if lesser check following level
dem10ms
	MOVLW	b'11011001'	; load 217 on DEMORA, corresponding with  10ms forTMR0
	MOVWF	DEMORA		;
	RETURN
nivluz2
	MOVLW 	b'11001100'	; load value to compare level with stimate 4V
	GOTO	dem9ms
	GOTO	nivluz3		; if lesser check following level
dem9ms
	MOVLW	b'11000011'	; load 195 en DEMORA que corresponding with 9ms para el TMR0
	MOVWF	DEMORA		;
	RETURN
nivluz3
	MOVLW 	b'10110010'	; cargo valor a comparar nivel con 3.5V
	SUBWF 	ls_adc,W	; comparamos ambos registros
	BTFSC	STATUS,Z	; Si son iguales se ejecuta la siguiente, en caso contrario se salta
	GOTO	dem8ms
	BTFSS	STATUS, C	; comprobamos el bit de complemento para saber si es mayor o menor
	GOTO	nivluz4		; en caso de que sea menor comprobamos siguiente intervalo
dem8ms
	MOVLW	b'10101101'	; cargamos 173 en DEMORA que corresponde con 8ms para el TMR0
	MOVWF	DEMORA		; ya que hay luz y no necesitamos que este encendida
	RETURN
nivluz4
	MOVLW 	b'10011001'	; cargo valor a comparar nivel con 3V
	GOTO	dem7ms
	GOTO	nivluz5		; en caso de que sea menor comprobamos siguiente intervalo
dem7ms
	MOVLW	b'10010111'	; cargamos 151 en DEMORA que corresponde con 7ms para el TMR0
	RETURN
nivluz5
	MOVLW 	b'01111111'	; cargo valor a comparar nivel con 2.5V
	GOTO	dem6ms
	GOTO	nivluz6		; en caso de que sea menor comprobamos siguiente intervalo
dem6ms
	MOVLW	b'10000010'	; cargamos 130 en DEMORA que corresponde con 6ms para el TMR0
	RETURN
nivluz6
	MOVLW 	b'01100110'	; cargo valor a comparar nivel con 2V
	GOTO	dem5ms
	GOTO	nivluz7		; en caso de que sea menor comprobamos siguiente intervalo
dem5ms
	MOVLW	b'01101100'	; cargamos 108 en DEMORA que corresponde con 5ms para el TMR0
	RETURN
nivluz7
	MOVLW 	b'01001100'	; cargo valor a comparar nivel con 1.5V
	GOTO	dem4ms
	GOTO	nivluz8		; en caso de que sea menor comprobamos siguiente intervalo
dem4ms
	MOVLW	b'01010110'	; cargamos 86 en DEMORA que corresponde con 4ms para el TMR0
	RETURN
nivluz8
	MOVLW 	b'00110011'	; cargo valor a comparar nivel con 1V
	GOTO	dem3ms
	GOTO	nivluz9		; en caso de que sea menor comprobamos siguiente intervalo
dem3ms
	MOVLW	b'01000001'	; cargamos 65 en DEMORA que corresponde con 3ms para el TMR0
	RETURN
nivluz9
	MOVLW 	b'00011001'	; cargo valor a comparar nivel con 0.5V
	GOTO	dem2ms
	GOTO	no_dem		; en caso de que sea menor no aplicamos ninguna demora
dem2ms
	MOVLW	b'00101011'	; cargamos 65 en DEMORA que corresponde con 2ms para el TMR0
	RETURN
no_dem
	MOVLW	b'00000000'	;no aplicamos ninguna demora, al estar en completa oscuridad
	MOVWF	DEMORA
	RETURN
;Tratamiento de los datos, accion de persiana..................................
persia
	BTFSC	estado,2	;testing shade bit
	GOTO	luz			; If 1 	I will check light state bit
	GOTO	oscuro		; If 0 I will check light state bit
luz
	BTFSS	estado, 3	; testing shade bit
	GOTO	abrir		; If closed, then will open the shade
	RETURN			; if it is openen, I do not anything
oscuro
	BTFSS	estado, 3	; testeo bit de estado
	RETURN			; if closed, nothing to do
	GOTO	cerrar		; If open, then will close the shade
abrir
	BSF 	PORTD,0		; writing 1 in RD0 to open
	GOTO 	espera5s	; Waiting  5 seconds (stimate time) to let the shade be totaly opened
	BCF	PORTD,0		; deactivate port D0
	BSF	estado,2	; Updating flag bit  estado to open
	RETURN
cerrar
	BSF	PORTD,1		; writing 1 por RD1 to close
	BCF 	PORTD,1		; deactivate port  D1
	BCF	estado,2	; Updating flag bit  estado to close
	RETURN
espera5s
		movlw     .165  	; 1 set numero de repeticion  (C)
        movwf     PDel0    	; 1 |
PLoop0
		movlw     .41      	; 1 set numero de repeticion  (B)
        movwf     PDel1    	; 1 |
PLoop1
		movlw     .147      	; 1 set numero de repeticion  (A)
        movwf     PDel2     	; 1 |
PLoop2
		clrwdt              	; 1 clear watchdog
        clrwdt              	; 1 ciclo delay
        decfsz    PDel2, 1  	; 1 + (1) es el tiempo 0  ? (A)
        goto      PLoop2    	; 2 no, loop
        decfsz    PDel1,  1 	; 1 + (1) es el tiempo 0  ? (B)
        goto      PLoop1    	; 2 no, loop
        decfsz    PDel0,  1 	; 1 + (1) es el tiempo 0  ? (C)
        goto      PLoop0    	; 2 no, loop
        return              	; 2+2 Fin.
	END
