PIC16F84A LED interrupt
monchichi
hi please help
i'm new just learn PIC for 1 week.
i'm currently using pic16f84a to do the LED display.
i want to the LED display and interrupt for 2sec after that LED display agian.
but doesn't work with the PIC i write.
list p=pic16f84a
include p16f84a.inc
__config _hs_osc & _wdt_off & _pwrte_on & _cp_off
errorlevel -302 ;
cblock h'0c'
count1
count2
endc
;**************** Program Start ***********************
org 0
goto start
;**************** Initial Process *********************
start
bsf status,rp0
movlw h'ff'
movwf trisa
clrf trisb
bcf status,rp0
movlw h'ff'
movwf portb
bsf intcon,f
loop
call timer
decfsz count1,f
goto loop
timer
movlw d'2'
movwf count2
end
please help.
Have a look at this program.:)
You were using the timer loops incorrectly.
This will flash an LED on/off on PORTB.
To change the flash rate, change this decimal.
movlw d'25'
movwf count1
	list	p=pic16f84a
	include	p16f84a.inc
	__config _HS_OSC & _WDT_OFF & _PWRTE_ON & _CP_OFF
	errorlevel -302		;
	cblock	h'0c'
count1
count2
	endc
	org	0
	goto	start
start
	bsf	STATUS,RP0
	movlw	h'ff'
	movwf	TRISA
	clrf	TRISB
	bcf	STATUS,RP0
	movlw	h'ff'
	movwf	PORTB
	bsf	INTCON,F
loop
	movlw	0xff
	movwf	PORTB
	call	timer
	movlw	0x00
	movwf	PORTB
	call	timer
	goto	loop
timer
	movlw	d'25'
	movwf	count1
lp0
	movlw	d'250'
	movwf	count2
lp1
	decfsz	count2,F
	goto	lp1
	decfsz	count1,F
	goto	lp0
	return
	end
BTW: you are not using Interrupts.
EDIT: Use this delay calculator for your programs.
