Pic16f690 eepprom
prean
hey guys.i set up a counterand im trying to write these values to the eeprom of the pic16f690 and then read the value. the read which is outputted to port C,where leds should display them. i taken the eeprom code from the data sheet however it does not work. i have pasted my code below. please could somebody help me. thank you
#include <p16F690.inc>
__config (_INTRC_OSC_NOCLKOUT & _WDT_OFF & _PWRTE_OFF & _MCLRE_OFF & _CP_OFF & _BOR_OFF & _IESO_OFF & _FCMEN_OFF)
cblock 0x70
DATA_EE_ADDR
DATA_EE_DATA
dly0
dly1
endc
org 0
nop
; intialise output ports
banksel ANSEL
movlw 0x00
movwf ANSEL
banksel ANSELH
movlw 0x00
movwf ANSELH
banksel TRISC
movlw 0xF0
movwf TRISC
movlw 0xF0
movwf DATA_EE_DATA
movlw 0x00
movwf DATA_EE_ADDR
WRITE
banksel EEADR
movf DATA_EE_ADDR
movwf EEADR
movf DATA_EE_DATA
movf EEDAT
banksel EECON1
bcf EECON1,EEPGD
bsf EECON1,WREN
bcf INTCON,GIE
btfsc INTCON,GIE
goto $-2
movlw 0x55
movwf EECON2
movlw 0xAA
movwf EECON2
bsf EECON1,WR
bsf INTCON,GIE
;SLEEP
;bcf EECON1,WREN
banksel PIR2
movlw 0x01
movwf PIR2
;incf DATA_EE_DATA
READ
banksel EEADR
movf DATA_EE_ADDR,W
movf EEADR
banksel EECON1
bcf EECON1,EEPGD
bsf EECON1,RD
banksel EEDAT
movf EEDAT,W
banksel PORTC
movwf PORTC
incf DATA_EE_DATA
;delay code
;movlw H'F0'
;movwf dly1
;movlw H'0F'
;movwf dly0
;OndelayLoop
;decfsz dly0,f -Waste time.
;goto OndelayLoop -The Inner loop takes 3instructions per loop * 256 loopss = 768 instructions
;decfsz dly1,f -The outer loop takes and additional 3 instructions per lap * 256 loops
;goto OndelayLoop
goto WRITE
end
Try the following code ...
	cblock 0x70
	DATA_EE_ADDR
	DATA_EE_DATA
	dly0
	dly1
	EE_ADR
	W_DATA
	R_DATA
	endc
	org 0
	nop
	banksel	ANSEL
	movlw	0x00
	movwf	ANSEL
	banksel	ANSELH
	movlw	0x00
	movwf	ANSELH
	banksel	TRISC
	movlw	0xF0
	movwf	TRISC
	movlw	0xF0
	movwf	DATA_EE_DATA
	movlw	0x00
	movwf	DATA_EE_ADDR
; To WRITE into EEPROM
	banksel EE_ADR
	movlw	0x00		; EE_ADDR
	movwf	EE_ADR		; move 0x00 into EE_ADR
	movlw	0x12		; Writes Hous data into EEPROM
	movwf	W_DATA		; Data to be written
	call	EE_WR		; Write routine for EE_Addr
; To READ from EEPROM
	call	EE_RD		; Read EEPROM Addr 0
	movwf	R_DATA		; Write into Hyst High register
;EE_WR			EEPROM DATA WRITE SEQUENCE
EE_WR
		banksel	EECON1 			; Select Bank of EECON1
		btfsc	EECON1,WR		; Wait for write
		goto	$-1			; to complete
		banksel	EE_ADR			;
		movf	EE_ADR,W 		;
		banksel	EEADR			; (0x10C) Select Bank of EEADR
		movwf	EEADR			; Data Memory Address to write
		banksel	W_DATA			;
		movf	W_DATA,W		; Register containing data to be stored
		banksel	EEDATA			; (0x10D)
		movwf	EEDATA			; Data Memory Value to write
		bsf	STATUS,RP0		;
		bcf	EECON1,EEPGD		; Point to DATA  memory
		bsf	EECON1,WREN		; Enable writes
		bcf	INTCON,GIE		; Disable INTs.
		movlw	H'55'			;
		movwf	EECON2			; (0x18C) Write 55h
		movlw	H'AA'			;
		movwf	EECON2			; (0x18C) Write AAh
		bsf	EECON1,WR		; Set WR bit to begin write
		bsf	INTCON,GIE		; Enable INTs.
		bcf	EECON1,WREN		; Disable writes
		banksel	PIR2			;
		btfss	PIR2,EEIF		; Wait for interrupt flag to be set
		goto	$-1			; Current line -1
		bcf	PIR2,EEIF		; Clear the EEWRITE interrupt flag
		return				; return to caller
;	EE_RD			EEPROM DATA READ SEQUENCE				;
EE_RD						;
		movf	EE_ADR,W		;
		banksel	EEADR			;
		movwf	EEADR			; Data Memory Address to read
		banksel	EECON1			;
		bcf	EECON1,EEPGD		; Point to Data memory
		bsf	EECON1,RD		; EE Read
		banksel	EEDATA			;
		movf	EEDATA,W 		; W = EEDATA
		banksel	R_DATA			;
		movwf	R_DATA			; Move W into EE_BYTE
		incf	EE_ADR,f		; increment EE_Addr with 1
		return				; Value now in W, to be used
; WRITE	routine to write data			;
; into EEPROM memory Hours			;
WriteEE:					;
		movwf	W_DATA			; Writes Hous data into EEPROM
	end
This does work.
hey thanx alot for your help. but it seems the counter does not output to the 4 leds in PORTC
Did you set up port C? I know you got to do something with ANSEL then set ports to input or output:
050 1683 BSF 0x3, 0x5 ; Set program counter to
051 1303 BCF 0x3, 0x6 ; Bank1 memory
052 1007 BCF 0x7, 0 ; Set Port C bit 0 to output
053 1087 BCF 0x7, 0x1 ; " " " 1 " "
054 1107 BCF 0x7, 0x2 ; " " " 2 " "
055 1187 BCF 0x7, 0x3 ; " " " 3 " "
