PIC12F508 : OPTION Register issue ( Using HI-tech Compiler)
Hi building a trigger circuit, so I'am required to generate continuous on-off pulse from the Microcontroller. I' am using Internal clock through the following instruction :
__CONFIG(MCLRDIS & WDTDIS & UNPROTECT & INTRC);
Then I tried to configure Timer0.
So I did the following.
T0CS = 0 //Transition on internal instruction cycle clock, FOSC/4
PSA = 0 // Prescaler assigned to Timer0
PS0=1;PS1=1;PS2=1 // For maximum prescaler of 1:256
( Used the above, from the header file pic125xx.h as:
/* OPTION bits */
#define GPWU (1<<7)
#define GPPU (1<<6)
#define T0CS (1<<5)
#define T0SE (1<<4)
#define PSA (1<<3)
#define PS2 (1<<2)
#define PS1 (1<<1)
#define PS0 (1<<0)
But the compiler threw up an error , as :
Error [202] C:\Users\Chetan\Desktop\Yogesh\pulse.c; 10.11 only lvalues may be assigned to or modified
Couldn't understand where I went wrong. I' am new to Hi-tech compiler and trying to get used to it. Any kind of help will be greatly appreciated and would be of lot of help.
Regards
Chetan Gowda
You are trying to give a constant a value which is not allowed.
Just write the whole register by doing, OPTION = 0b11000111;
Or, to set the prescaler do OPTION |= 0b00000111;
And to clear TOCS do OPTION &= ~TOCS;
HTH
