PIC Voltage Meter
iflymyhelishigh
Hi guys, I am working on a PIC Voltage Meter. Apparently I should be using a PIC with a Analog input, and I have chosen a PIC16F88 for that.
I want to measure voltages up to 12 volts, and display it on a 16X2 HD44780 compatible screen. Apparently I need to have a resistor voltage divider for that, is there a formula to come up with the resistor values I need?
What do you think I will need for this project? I am thinking just a very simple PIC itself, resistor voltage divider, and LCD screen. The power supply I am using to monitor the voltage has a 5 volt output, so I am covered with the voltage supply.
Thanks guys, iflymyhelishigh
Check my analogue tutorial, which explains all you need to know - and is very easy to move to a 16F88.
I would advise an opamp buffer (as my tutorial uses) because the analogue inputs need a low source impedance.
If the analog voltage is slow moving, a 0.1uF cap at the PIC's input should be plenty enough to swamp the sample and hold cap.
And would make the situation massively worse - so how would that help?.
If the input is slow moving it doesn't matter anyway, as long as you're not switching inputs - if you do, you have to allow time for the capacitor to charge or discharge.
