Pic to Pic communication
neelam29
Hi all
i want to design a project in which i want to make to and fro communication between 2 pic microcontrollers . both are PIC16f684.
want to use either 1 wire or 2 wire to communicate.Please help me how to proceed .
thanks
Just use serial communications, on either one pin, or two pins - with two pins you can use the hardware USART's, with one pin you need to use software ones.
thanks nigel..but wht software u mean to say if i use 1 pin...i dont wanna go for uart.. please explain in detail..i couldnt get ur point
If you use one pin you have to keep switching them from input to output, which you can easily do in software - normally both PIC's would be set as inputs, to send data one would switch to output, send the data, then switch back to an input and wait for the reply. The second PIC, havng received the data, would switch to be an output, and send the reply back to the first, then return to being an input.
You need to decide exactly what you want to do, and how you want to do it.
We are also doing a PIC to PIC communication.. Both PIC are 18F4550..
We wanna use the Streaming Parallel Port on both devices..
How do you use SPP??
Please help.. Thank you
