pic MC
Elecman2000
Is it necessary to use Two power supplies separated , one for the pic and the other for the load, or One is enough and separating the two circuits by opto ???
What load?
Not enough information.
If your load needs the same voltage as the PIC then use one supply.
Power the PIC from a 5 volt supply. (3.3V)
Power the motors form a 24 volt supply.
Connect the two grounds together.
You can also use a LM7805 to change 24V into 5V. That way everything can run from 24V.
Wooo, don't forget the heatsink!!
24V to 5V is a pretty hefty power dissipation task for a linear reg!
I would use a DC-DC converter, or switching reg as they are sometimes known.
I would drive the motors using FET's correctly rated, or, an automotive relay. I would chose the relay personally, no heat to dissipate.
Just my 2 pence worth!
Wilksey
LCD program
hi now am doing program to display string on lcd using micro controller can anyone give the coding of that
Determined.. I'll give you that...
There are LCD tutorials, in C on this forum... There is a link in my signature.
When you post.... Try to start a new thread...... When you hi-jack someone else's thread.. People tend to ignore you...
There is a 8051 section for this processor and you will get more people looking at the post.
You should include as much info as possible..... MCU type... LCD you need to use.... CODE choice asm... c pascal etc....
Some people here are very good... but cannot read minds.
Wilksey
I made h-bridge by tip 122 and 127, one of them exploded it got so freakin hot, no wrong made in the connection ,,, A relay would be the right selection, but does this mean that high power transister is not reliable in such application ?
We need more information! I know you are using TIP122/127. I do not know how you used these parts. The how is very important.
It looks like you connected the base of Q5 to the base of Q6. That will kill a transistor.
There are H bridge ICs. Many different types. Some have 4 or 3 or 2 inputs, with different logic. You should look at them.
