PIC communication with external serial flash
mzd2
I'm having some trouble getting a PIC16LF88 to write to/read from an external flash memory. The memory is ST Microelectronics M45PE80.
Has anyone used these 2 products together, and if so, does anyone have any code I could take a look at for successfully writing to and reading from the M45PE80?
I could also post my (unsuccessful) code, if anyone wants to take a look.
I'm going to go ahead and post my code so everyone can take a look at it.
I'm only posting the relevent portions of code, though I could post the whole program if I need to. Just to clarify a couple things:
-I'm using a PIC16LF88 with an M45PE80 serial flash memory
-"CSEL" is the microcontroller pin that is connected to the chip select pin on the M45PE80
-"SEND" and "RECEIVE" subroutine send and receive to/from the UART. I won't post them, I know they are working.
-Here's what I want it to do:
1.) Prompt for a character
2.) Store that character in a data buffer (called DBUF, location h'3C'.
3.) Write that character to the external flash memory
4.) Prompt to Upload data, if yes, then move byte of data from flash memory back to data buffer
5.) Send that character back to the UART
Here's the code. If you need to see anything else, let me know.
;short (50 us) delay subroutine:
DELAY    movlw    h'10'    ;49 cycles
       movwf    d1
dloop    decfsz    d1,f
       goto    dloop
       nop                ;1 cycle
       return
;delay to wait for SPI send/receive to finish (checks BF flag only)
BFWAIT    bsf        STATUS,5    ;bank 1
       btfss    SSPSTAT,BF    ;test if send/receive is complete
       goto    $-1            ;loop until receive is complete
       bcf        STATUS,5    ;bank 0
       return
;Wait for flash writing to be complete
WRTWAIT    movlw    b'11111111'
       movwf    TMP            ;set all TMP bits
WRTLOOP    bcf        CSEL        ;select flash
       movlw    h'05'
       movwf    SSPBUF        ;send read status register command
       call    BFWAIT        ;wait for byte to be sent/received
       movlw    h'00'
       movwf    SSPBUF        ;send dummy character
       bsf        CSEL        ;deselect flash
       movf    SSPBUF,W    ;move received data to W
       movwf    TMP            ;then move to scratch
       btfsc    TMP,0        ;check 'write in progress bit'
       goto    WRTLOOP        ;if still writing, check again
       return
;Set up SPI module
;data shifted out of M45PE80 on falling edge of clock
;data shifted into M45PE80 on rising edge of clock
SPIINT    bsf        STATUS,5    ;bank 1
       movlw    b'10000000'    ;input data sampled at end of data output time
       movwf    SSPSTAT        ;txmit occurs on trans. from idle to active
       clrf    SSPCON        ;txmit happens on rising edge, idle state is low
                           ;SPI module disabled
                           ;SPI master mode, clock= OSC/4
;Test flash memory (M45PE80)
MEMORY    movlw    h'3C'
       movwf    BUFPT        ;set buffer pointer to bottom of buffer
       movf    BUFPT,W
       movwf    FSR            ;set indirect location
       clrf    BUFCT        ;clear buffer counter
MPROMPT    movlw    'W'            ;">WRITE ADC OUPUT?"
       call    SEND        ;
       movlw    'R'
       call     SEND
       movlw    'I'
       call    SEND
       movlw    'T'
       call    SEND
       movlw    'E'
       call    SEND
       movlw    ' '
       call    SEND
       movlw    'A'
       call    SEND
       movlw    'D'
       call    SEND
       movlw    'C'
       call    SEND
       movlw    ' '
       call    SEND
       movlw    'O'
       call    SEND
       movlw    'U'
       call    SEND
       movlw    'T'
       call    SEND
       movlw    'P'
       call    SEND
       movlw    'U'
       call    SEND
       movlw    'T'
       call    SEND
       movlw    h'0D'
       call    SEND
       movlw    h'0A'
       call    SEND
       call    RECEIVE        ;get character
       movf    INPUT,W        ;move input character to W
       movwf    INDF        ;move input character to data buffer
   ;getting everything set up for flash write:
FLWRITE    bcf        RCSTA,SPEN    ;disable serial port
       bcf        TRISB,2        ;set RXD/SDO pin as output for SPI communication
       bsf        SSPCON,SSPEN    ;enable SPI module
       call    WRTWAIT        ;make sure no writing is happening
       call    DELAY
       movlw    h'06'        ;move write enable (WREN) instruction to W
       movwf    SSPBUF        ;send WREN instruction
       call    DELAY
       movlw    h'02'        ;move page  program instrction to W
       bcf        CSEL        ;pull chip select low
       movwf    SSPBUF        ;send page program instruction
       movf    NAFLH,W
       movwf    SSPBUF        ;send high byte of next available flash address
       movf    NAFLM,W
       movwf    SSPBUF        ;send mid byte of address
       movf    NAFLL,W
       movwf    SSPBUF        ;send low byte of address
   ;moves data buffer to flash:
       movf    INDF,W        ;move data byte in buffer to W
       movwf    SSPBUF        ;send data byte
       call    WRTWAIT        ;wait for writing to be complete
       bcf        SSPCON,SSPEN    ;disable SPI module
       bsf        RCSTA,SPEN    ;enable serial port
       bsf        TRISB,2        ;set RXD/SDO pin as input for serial communication
OUTPUT    movlw    '>'                ;">UPLOAD?"
       call    SEND
       movlw    'U'
       call    SEND
       movlw    'P'
       call    SEND
       movlw    'L'
       call    SEND
       movlw    'O'
       call    SEND
       movlw    'A'
       call    SEND
       movlw    'D'
       call    SEND
       movlw    '?'
       call    SEND
       movlw    h'0D'
       call    SEND
       movlw    h'0A'
       call    SEND
       call    RECEIVE        ;wait for any input
UPLALL    clrf    DBUF        ;clear 1st byte in buffer, to make sure it is actually getting writting/read to flash
       movlw    h'3C'
       movf    BUFPT,W
       movlw    h'03'
       bcf        CSEL        ;pull chip select low, select flash
       movwf    SSPBUF        ;send READ instruction
       movf    NAFLUH,W
       movwf    SSPBUF        ;send high address byte
       movf    NAFLUM,W
       movwf    SSPBUF        ;send mid address byte
       movf    NAFLUL,W
       movwf    SSPBUF        ;send low address byte
       movlw    h'00'
       movwf    SSPBUF        ;send null character to initiate transmission
   ;now moving this byte to the buffer:
       movf    SSPBUF,W    ;move received byte to W
       movwf    INDF        ;move to data buffer
       bsf        CSEL        ;pull chip select high
       bsf        TRISB,2        ;set RXD/SDO pin as input for UART
XMIT    movf    INDF,W        ;move byte to W
       call    SEND        ;send first byte of buffer
       movlw    h'0D'        ;CR
       call    SEND
       movlw    h'0A'        ;LF
       call     SEND
       movlw    '>'
       call    SEND
       movlw    'D'            ;>DONE?
       call    SEND
       movlw    'O'
       call    SEND
       movlw    'N'
       call    SEND
       movlw    'E'
       call    SEND
       movlw    '?'
       call    SEND
       movlw    h'0D'
       call    SEND
       movlw    h'0A'
       call    SEND
       movlw    'y'            ;test for input of y
       subwf    INPUT,f        ;by subtraction
       btfss    STATUS,2    ;skip next if input is y
       goto    MEMORY        ;if anything else, go back to MEMORY, repeat
       goto    MENU
hi am about to start the same project
connecting usb flash memory + pic
can u help me since i dont know where to start
any help is appreciated?
thanx in advance
You've already been told in your previous thread, DON'T USE USB MEMORY!.
Notice this thread isn't about USB at all.
