PIC C18 External Interrupts INT0
natraj20
Hello guys,
Problem with the very basics.
I am stuck with the external interrupt INT0 at RB0.
Controller - PIC 18F47J53
MPLAB IDE, Microchip C Compiler
I could not figure out what is wrong with the following code. Kindly help me out to make this work!!
#include <p18f47j53.h>
#include <delays.h>
#include <portb.h>
#pragma config OSC = HS
#pragma config WDTEN = OFF
#pragma config XINST = OFF
void InterruptServiceHigh(void);
void InterruptServiceLow(void);
int x;
void main(void)
INTCONbits.INT0IF = 0;
INTCONbits.INT0IE = 1;
INTCON2bits.INTEDG0 = 1;
INTCON2bits.RBPU = 0;
//EnablePullups();
TRISE = 0;
TRISBbits.TRISB0 = 1;
RCONbits.IPEN = 1;
INTCONbits.GIE = 1;
INTCONbits.PEIE = 1;
while(1)
PORTE = 0x01;
// High priority interrupt vector
#pragma code InterruptVectorHigh = 0x08
void InterruptVectorHigh(void)
_asm
goto InterruptServiceHigh
_endasm
// Low priority interrupt vector
#pragma code InterruptVectorLow = 0x18
void InterruptVectorLow(void)
_asm
goto InterruptServiceLow
_endasm
// Interrupt Service Routine
// Interrupt pragma for high priority
#pragma code
#pragma interrupt InterruptServiceHigh
void InterruptServiceHigh()
// function statements
if(INTCONbits.INT0IF)
x = 0;
while(x <= 2)
PORTE = 0x01;
Delay10KTCYx(120); // Delay of 1 sec with 12 MHz
PORTE = 0x02;
Delay10KTCYx(120);
x++;
// return from high priority interrupt
// Interrupt pragma for low priority
#pragma code
#pragma interrupt InterruptServiceLow
void InterruptServiceLow()
// return from low priority interrupt
Hello guys,
#include <delays.h>
#include <portb.h>
int x;
void main(void)
    //EnablePullups();
    TRISE = 0;
    RCONbits.IPEN = 1;
    INTCONbits.GIE = 1;
    while(1)
        PORTE = 0x01;
    _asm
    _endasm
    _asm
    _endasm
#pragma code
        x = 0;
        while(x <= 2)
                PORTE = 0x01;
                PORTE = 0x02;
                Delay10KTCYx(120);
                x++;
#pragma code
I placed your source between code tags (Use the # key when you post. It keeps your formatting, so it is easier to read your code.
I didn't take a close look, but one thing which jumped out was that you are calling a delay from your interrupt service routine. That isn't a good habit to get into, and often makes a program fail.
The preferred way to do this it to set a flag variable in the ISR, and check for that flag in your endless loop. ie: while(1){ if(interrupt_flag) do what i want; call as many delays as I want;}
regards
EDIT: You may find that flashing just a single LED as a subroutine, from within main is a good debugging technique. You can put the call to it most anywhere to know if the chip gets to it.
Here is your code. You missed to put in values if ANCON0 and ANCON1 to configure the pins as digital(datasheet page 371).
#include <delays.h>
#include <portb.h>
int x;
void main(void)
	[B][COLOR="red"]ANCON1=0xff// sets all Analog
	ANCON0=0xff;//pins as digital[/COLOR][/B]
    //EnablePullups();
    TRISE = 0;
    RCONbits.IPEN = 1;
    INTCONbits.GIE = 1;
    while(1)
        PORTE = 0x01;
    _asm
    _endasm
    _asm
    _endasm
#pragma code
        x = 0;
        while(x <= 2)
                PORTE = 0x01;
                PORTE = 0x02;
                Delay10KTCYx(120);
                x++;
#pragma code
