PIC assembly programming
$ stands for the current address...
So
GOTO $ + 1 means, Goto the next line
GOTO $ + 3 means, Go 3 lines ahead (skip 2)...
and GOTO $ is an endless loop, cause it keeps going to the same adress
aniketrane said:
what does "$" signify in assembly code. e.g code are
goto $;
or
goto $+1;
It's in the MPASM help file, '$' means the current address, so 'GOTO $' is an endless loop, 'GOTO $+1' is like a NOP, but takes 2 cycles rather than one - so can be quite handy.
GOTO $-1 (or other minus numbers) is probably most useful, it saves you having to use a label for a jump - like this:
        BTFSS Dummy, 1
        GOTO $-1
Instead of:
Loop BTFSS Dummy, 1
        GOTO Loop
It appears in some of my tutorials, and I explain it there.
comparing...
how 'bout in comparing?
what are the different syntax and/or techniques can be used in comparing?
of course still in pic assembly!
just comparing numbers?
Well, the pic is a risc µC, so there aren't any instructions that allow direct comparison of 2 variables, so you'll have to use tricks to get it done (as with any risc based system)
For example, if you want to see if number1 is bigger then number2 you just subtract number1 from number2 and if the borrow flag is set (a flag that indicates the result went below 0 and 'rolled over' back to 255) then number1 was bigger
To see if 2 numbers are the same you can XOR them, if they are the same then the result is 0
