aljamri
I'm doing Analog Tutorial from Nigel's. (Tutorial # 11), replaced 16f876 with 16f876a. LCD not seemed initialized, regardless hardware double check the following findings still exist:
• LCD not initialized ( top line blocks only )
• If +5 volts connection to MCLR ( pin #1 ) moved two, three times, LCD initialized,
• When LCD initialized, it may show two lines or one line sometimes.
• If the LCD shows two lines, it removes the first an second characters from Tutorial ( appears torial )
Note: I could not find 12 Pico Capacitors for Main Board 2, I put 6 Picos.
Is there any thing wrong in all of these.
