PIC 16f876 data eeprom write
SuperBud
I have a problem with data eeprom write routine. I use the routine in PIC's datasheet but pic doesn't esc of sleep mode.
Can you help me?
Thank you
SuperBud
You might get responses if people could understand what you mean. Could you please explain your question a little bit clearer please.
This is the routine :
; the value to write is in variable sup
; the address si in register w
Scrivi_Dato
BSF STATUS, RP1
BCF STATUS, RP0 ; Bank 2
movwf EEADR ; EEADR<=w
Banksel sup
Movf sup,0 ;w<=sup
BSF STATUS, RP1
movwf EEDATA ;EEDATA<=w
BSF STATUS,RP0 ; Banco 3
BCF EECON1,EEPGD ;Punta alla Data Memory
BSF EECON1,WREN ;Abilito la scrittura
BCF INTCON,GIE ;Disabilita interrupt
movlw 55h
movwf EECON2
movlw 0AAh
movwf EECON2
BSF EECON1,WR ;Abilito scrittura
BSF INTCON,GIE ;Abilita interrupt
SLEEP
BCF EECON1,WREN ;Disabilito scrittura
Return
the program remains blocked on instruction SLEEP.
Excuse me for my bad English i hope that you can understand my problem and help me.
Thank you
Bye
In addition to the global interrupt enable GIE, I think you need to enable EEIE bit in PIR2 to get an interrupt to come out of SLEEP. You also have to have an interrupt service routine at location 4 to clear the EEIF bit.
I don't use this routine myself. Since writing to the eeprom takes a long time, I simply return from this eeprom write routine and clear the WREN bit elsewhere. Anyway, a simpler routine instead of using SLEEP and interrupts is as follows:
WAIT:
    BTFSC    EECON1,WR
    GOTO     WAIT
    BCF      EECON1,WREN
