PIC 16F84a to measure resistance for switch positions
5neaker
Hi
I’m new to the wonderful world of PIC.
I want to build a circuit to detect which position a switch has been pushed. The switch has only one signal wire and a ground to measure the different positions.
The switch contains various smd resistor ladders. I need PIC 16F84A to looks at the various resistor ladders to know which direction the switch has been pushed.
I’ve measured the resistance for each of the position,
Left – 679 ohm
Right – 1536 ohm
Up – 471 ohm – this is the one I’m interested in
Down – 220 ohm
When the position is found I would like it to light up an LED indicator
I did try to measure the voltage using 5V supply, in all the position I get a reading of 5V. I need to measure the resistance
Any help would be appreciated greatly, code, circuit diagram etc
Thanks in advance
Ray
This requires, *i think*, the command "Read ADC". This is an analog input for the PIC. As far as i know of this is the only command that can read analog inputs.
Off topic: Did any one see the world cup final between Australia and England??
5neaker said:
Hi
Left – 679 ohm
Right – 1536 ohm
Down – 220 ohm
Thanks in advance
Ray
Yes, you'll need a PIC with a ADC, or an external ADC to work with your F84. The reason you measure 5V in all positions is because you're not getting any current trough those resistors. There will only be a voltage drop over a resistor when you make current go trough it.
add a 1K resistor between your switches output and GND. Now measure on the switch. Voltage will now change along with the resistance of the switch.
Exo said:
5neaker said:
Hi
Left – 679 <a href="#">ohm</a>
Right – 1536 <a href="#">ohm</a>
Up – 471 <a href="#">ohm</a> – this is the one I’m interested in
Down – 220 <a href="#">ohm</a>
Thanks in advance
Ray
Thanks Exo, could you send me any example external ADC work with the F84.
I ofthen use a MCP3221 from microchip
12 Bit A/D in a small SOT23 package. It uses I2C protocol wich only requires 2 wires between the converter and the pic
I2C code can be found on many places on the net, including nigel's site
www.winpicprog.co.uk
