Personal DAB - Adding External Aerial (Modding It!)
crocket
Hello!!
I'm trying to add this DAB unit into my car as it's really small and would fit where I wanted it to fit exactly.
The signal will be poor on the move, so I have installed a blaupunkt DAB aerial to my car which provides a coax which I can connect to my DAB unit.
The unit I have bought is this...
It get's the signal from the earphones somehow, probabily using the shielding.
It's a standard 3.5mm jack (standard 3 pole)
Which pole(s) do I attach the DAB aerial to get it to work correctly?
Hope you can help!
After doing some research, do I connect the middle of the aerial coax connector to the ground (outer pole) on the headphone socket?
