PCI-E Connector in Cadsoft Eagle
JFDuval
Hello!
I need to use some 164 contacts PCI-Express connectors for a project. Before creating one in Eagle, I tought I could ask here if someone already have one?
asking for eagle libs is like an internet 'taboo' or something - if anyone has the library, they're not likely to share it with you.
you could try asking over at sparkfun's forums - lots of eagle users busy designing pcbs
https://forum.sparkfun.com/viewforum.php?f=20
Hello!
I don't understand why it should be taboo. I'm in favor of sharing every development I do. If someone need a library I've done, I'll give it to him with a smile!
Hello!
I did the library I needed. You can download it at:
It will appear on the Download section of Cadsoft.de in a few days.
Enjoy!
PCI to Parallel
Hello
Does anyone have a conversion table for PCI direct connect to parallel pinout for custom card.
Like
Pin#1 on Parallel port = Pin#? on PCI card edge
Pin#2 on "" "" = Pin#? on PCI card edge
Pin#3 ..... etc, etc.
PCI-e X1
I wanted to ask if someone has come accross the PCI-e X1 connector and pcb edge connector (fingers).
I wanted to try a design I am planning / thinking, and want to try and make my own 2 sided pcb (or single side if possible).
I found the X16, but just need the X1 :)
Any assistance would be appreciated.
Btw, does anyone know how I will be able to make the pcb "free form" so that later, if I am unable to cut the pcb correctly, I can just send it to a pcb house to have it done.
I am eager to try out a few things, and I need some or plenty ;) of help to achieve what I would like to do.
Thank you in advance to anyone able to help me.
p.s. Have I mentioned I just need a simple two-sided version, not layers? ;) :eek:
p.s.2 Just curious, can PCI-e work on a single side? or does it need both sides of the connectors for X1? I haven't fully read everything yet on the specification, but found a couple of I.C.'s that seem possible to do on a single layer, that is why I am asking. I just hate doing "via's" :(
