andrew2022
what do you think is the best chemical to use for pcb etching?
Ferric Chloride is quite good as you can use over and over if you run electricity through the used etchant. (electrolysis) the copper simply builds up over the terminals and the etchant regains it's corrosive form again.
Johnson777717 said:Ferric Chloride is quite good as you can use over and over if you run electricity through the used etchant. (electrolysis) the copper simply builds up over the terminals and the etchant regains it's corrosive form again.
I haven't ever performed the electrolysis on Ferric Chloride. What kind of voltage and amperage do you use to perform this? Any special procedures?
Thsi process would be extremely helpful, considering most regulations wont allow you to dispose the Ferric Chloride down the sewer due to the copper content. The regulations that I have read instruct to remove the copper, add baking soda in order to even out the PH level to around 7, and then flush into the sewer.
Thanks for the great idea!![]()
but then if it was corrosive again you wudnt need 2 get rid of it down the sewer
Ferric chloride is like auto coolant. You cannot re-electrolyze it repeatedly without affecting its quality or appearance. Eventually it will resemble Gatorade and will need to be disposed of safely and properly. If it were possible to re-use it this way, it would be more expensive to manufacture and distribute, and MG Chemicals would be short-lived.
