pc sound card question
ghostman11
does anyone happen to know what the max input voltage on the line in socket is on a normal pc sound card, i have trawled a bit and from what i have read it seems to be around 0.7 volts! this seems realy low to me.
the end app is to connect a pic to it so i can amplify sound out put from an alarm.
I think the .7 volts guess might be a bit high, line in voltages are supposed to be around 200mv's
Be careful which and what kind of attenuator you use, since this are relatively low voltages you could get more noise than signal, so carefully observe S/N ratio. Resistors by themselves always inject electrical and thermal noise.
It's not any kind of problem, these are line level signals, which are a relatively high level - far, far, above any kind of resistor noise.
the pc idea was purely to plug the output from the pic into the line in or mic of sound card and play the alarm thru the pc speakers, i need it fairly loud so it can be heard at a distance,
loud enough to be heard from inside one building to another 20-30 feet away and the signal is 5v from a pic.
the speakers i had in mind plug into the mains and when they are on full they are realy loud!! but i have no idea of the specs, i guess my other option would be to lay a cable into the office from the outbuilding and have a smaller speaker with some kind of amp
Assuming they are PC Speakers, then they have an internal amplifier, so you can feed them from the PIC via a simple resistive attenuator - try a 10K and a 1K.
