Welcome to our site! Electro Tech is an online community (with over 170,000 members) who enjoy talking about and building electronic circuits, projects and gadgets. To participate you need to register. Registration is free. Click here to register now.
I plan to use a 7809 and 7909 with a SPDT switch on the +/-12V output, to produce 9/12 volt interchangably (but using different output sockets), and add a slow-blow 1A fuse to the 0v output.
The 0V rail is internally bonded to earth ground in the power supply. If the output shorts to the metal case or another earthed object like a metal radiator the fuse won't blow.
Put fusses on all the outputs you intend to use. The power supply should be protected against short circuit anyway but you never can rely one it.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
